Old 08-28-2012, 04:09 PM   #1
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Question Seam Sealer for Tranny Hump?
Another dumb question, but this is new stuff to this old guy. When you re-install a high hump, what do you use for sealer? Is the OEM stuff still available at GM dealers (or elsewhere) or is there something better?
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Old 08-28-2012, 04:22 PM   #2
shawno72
C/10 junkie
shawno72's Avatar
Re: Seam Sealer for Tranny Hump?
Would like to know as well.
Shawn
70 LWB C10 current driver/project
http://67-72chevytrucks.com/vboard/s...d.php?t=663051
68 SWB C10 Work in progress.....SOLD
http://67-72chevytrucks.com/vboard/s...d.php?t=559520
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
http://youtu.be/kbB0QrBIs9k
My mom always had the best advice. It was just a tad late. After a fall that involved blood, she'd say....."Careful!"
shawno72 is offline   Reply With Quote
Old 08-28-2012, 05:14 PM   #3
LockDoc
The Older Generation
LockDoc's Avatar
I used ROPE CAULK. you should be able to get it at your local hardware store.
LockDoc
Leon
Old 08-28-2012, 05:17 PM   #4
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Thumbs up Re: Seam Sealer for Tranny Hump?
Thanks, Leon! I'll see if they have it.
- Mike -
RIP El Jay
Old 08-28-2012, 05:21 PM   #5
vectorit
What?
vectorit's Avatar
I just used a high temp silicone.
It was not the type one uses as a gasket sealer, it was a type that stays some what tacky. I have had to remove the hump twice since laying down a large bead, and all I do is mold it back into a bead and then set the hump back down and it seals up again just fine. I then just take a rag and wipe away the excess that squeezes out.
Can't remember the brand, but it comes in a large tube for a caulking gun.
The color is graphite.
Chris
1968 K20 Suburban
1972 K10 LWB PU
vectorit is offline   Reply With Quote
Old 08-28-2012, 06:47 PM   #6
AirSpeed
AirSpeed's Avatar
I used seem sealer for steel roofs. it's a butal tape that comes in a roll with a wax paper removable backing. It stays soft forever and conforms to every contour. Clean and easy to use and only cost about $5 for a 20 ft roll. You can get it at any large hardware store that sells steel roofing. If you ever need to remove the hump it will come right up as it doesn't harden.
AirSpeed is offline   Reply With Quote
Old 08-28-2012, 07:20 PM   #7
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Hmmmm, I have access to something that sounds identical, at an unbeatable price.... if it's still there. If not, I have a couple other great suggestions. Thanks, guys.
- Mike -
RIP El Jay
Old 08-28-2012, 07:22 PM   #8
builtnb
Active Member
I use 3M Windo-Weld Ribbon (3/8" X 15' round bead). Its very sticky, water proof, part nummber 08612.
builtnb is offline   Reply With Quote
Old 08-28-2012, 08:18 PM   #9
Daaaanz67
What airspeed said bought mine from napa/rebies works real nice stays soft oh and it's the3/8 thickness
Daaaanz67 is offline   Reply With Quote
Old 08-29-2012, 04:26 PM   #10
cheyenne shortstep
cheyenne shortstep's Avatar
Butyl Tape or window weld works well. Silicone sealer will attract and trap moisture causing rust issues and should not be used on body surface.
cheyenne shortstep is offline   Reply With Quote
Old 08-29-2012, 05:16 PM   #11
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Well, my local hardware didn't have a lot to choose from. I ended up using a complete 10.5 oz. tube of gray Big Stretch sealant. It sets up firm (not hard) and retains some flexibility, so it can bend & stretch without cracking or breaking.
- Mike -
RIP El Jay
Old 08-30-2012, 11:22 AM   #12
OldCreek
OldCreek's Avatar
Butyl tape for sure.
I bought a large roll from the local marine supply for about $7. It's reusable, waterproof, somewhat firm, not silicone, and cheap. Guys use it on bolts to seal their deck hardware and window ports from leaking through... so it's gotta work!
1972 K20 Suburban 5.7/700r4/NP205 Dana 44/H052 Sold
1972 C10 5.3L/4L60E 12bolt 5Lug - Sold
1971 K5 Blazer 6.0L LQ9 4L60E NP205 Dana 44/H052!!!
1970 K3500 1ton CrewCab 8.1L/Allison1000/NP205 Dana 60/14B!!!! - Sold
1984 K10 SWB 7.4L/4L80e/NP208 Corp 10/12 bolt Sold
1988 V30 CCLB 7.4L/TH400/NP205/Dana 60/Dana 70/3.73!!! (Sold)
2003 K2500HD 8.1/Allison1000/NP263
OldCreek is offline   Reply With Quote
Old 08-30-2012, 02:07 PM   #13
72chevyk10
I built it
72chevyk10's Avatar
i used liquid gasket maker on mine and it seals up good
'72 k10 lwb 454, th400, 205, d44ft, 12b rear, 4in skyjacker, 35x12.5-15 superswampers, 4.56, blazer tank. painless wiring harness
'98 dodge 3500 12v 5sp 4x4. the truck that actually runs
I think the best and cheapest performance mod is to have someone that knows what the hell they are doing perform a tuneup on said vehicle.
72chevyk10 is offline   Reply With Quote
