Old 08-30-2012, 11:58 AM   #1
82ccshorty
82ccshorty's Avatar
how much lift to clear 46s?
i am about to look at a crew cab 74 4x4 and the guy has a set of 46s for sell. so i was thinking if i can buy as a package deal why not put them on it? well i need to know how much lift i need and where to get one to clear 46s.
1969 chevy camaro Z28 #matchin Factory 4wheel disc
1969 chevy cst10 big block overdrive 5/7 drop dog dishs
1997 gmc yukon 2 door 2 wheel drive project 4/5.5 22s
2004 gmc sierra dually 4/4 lowering daily driver
82ccshorty is offline   Reply With Quote
Old 08-30-2012, 02:25 PM   #2
wwj75c30
wwj75c30's Avatar
Re: how much lift to clear 46s?
id do about 12" spring 2" shackle maybe 3" bodylift and 12" spring out back with small shackle flip or this
http://www.customsuspension.com/stor....php?cPath=438
wwj75c30 is offline   Reply With Quote
Old 08-30-2012, 02:38 PM   #3
82ccshorty
82ccshorty's Avatar
Originally Posted by wwj75c30 View Post
i love this place.
Old 08-30-2012, 03:55 PM   #4
wwj75c30
wwj75c30's Avatar
thats to much for me but eventually ill run a 10"-12" on my set of 40x15.50x20 toyo m/ts on some 20x14s
Old 08-30-2012, 03:59 PM   #5
82ccshorty
82ccshorty's Avatar
30 inch springs? whats that for like 64 inch tractor tires?
Old 08-30-2012, 04:09 PM   #6
Billett
Billett's Avatar
these lol
Will
1968 C10 - Project Texa Go 6.0/4L80e
2003 Mitsubishi Lancer Evolution
2002 Ford Excursion 7.3L
2024 Toyota Sienna
Billett is offline   Reply With Quote
Old 08-30-2012, 04:50 PM   #7
82ccshorty
82ccshorty's Avatar
Ha that's true
Old 08-30-2012, 10:10 PM   #8
Dooley
Dooley's Avatar
What gears are you planning to run with the 46"s? I have 395/85-20's, (46.5" tall) on a couple trucks. They do increase top end but, sap speed/power in the up grades. And that is with 6.72 gears.
Dooley is offline   Reply With Quote
Old 08-31-2012, 09:56 AM   #9
canadian 4x4
canadian 4x4's Avatar
a buddy of mine has 46 baja claws on an 85 crew. 8" leafs 5 inch blocks in the back plus he made is own spring hangers. he figures about 20inches of lift. top of the box is at 7ft
85 swb c10 6/6 drop
83 c10 bagged and sfbd project
canadian 4x4 is offline   Reply With Quote
Old 08-31-2012, 09:57 AM   #10
82ccshorty
82ccshorty's Avatar
Got any pictures of it?
Old 08-31-2012, 10:46 AM   #11
82ccshorty
82ccshorty's Avatar
Let's see them and I don't know yet on gears
Old 08-31-2012, 07:09 PM   #12
Hoods69BadBowTie
Chevys Kick A$$
Hoods69BadBowTie's Avatar
That would be a pretty sweet setup for sure. Gotta love them big lifted chevys nothing looks better then them! I would say like 12-14" on the lift at least for those big meats. Sounds like its gonna be a cool project if you get it.
*HOODS is what I answer too*
-'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold
-'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit
-'86 K5 Blazer Silverado 6.2 4" lift 35"s
-'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's
-'83 Monte Carlo T-Tops. 126,500 Original Miles
-LATER
I would rather push a Chevy then drive a ford!!
Hoods69BadBowTie is offline   Reply With Quote
Old 09-01-2012, 03:09 AM   #13
blazinzuk
blazinzuk's Avatar
If your not going to trim your fenders it would behoove you to move the front axle forward some.
Without trimming I would say a 12" spring, longer shackles, zero rate ( or ez inch) in the front. Out back something to match, then a 3" body lift, you still might rub a little bit.
But there are tons of ways to do this. 12" springs ride like a brick, those springs posted above make a brick look like a cushy pillow. The don't have much movement at all.
The best way here I think is to get a B-52 kit from DIY 4x, then some custom deavers, you should be able to get about 15" of lift out of a decent riding spring and the longer spring will help the ride. Even with that you will probably still need the body lift.
Don't forget steering. Crossover steering is best at those nosebleed heights
Eric
89 diesel jimmy
86 crew dually
87 truggy Horton
blazinzuk is offline   Reply With Quote
Old 09-01-2012, 04:38 AM   #14
spencer_41188
spencer_41188's Avatar
its gana take some axle work up front to get that pinion angle right and you will still overheat your u joints
cutting the weld on the inner c's and clocking them to get the caster right and building the front spring hanger lower then the shackle so you dont have to wedge it so much
the rear is easer just cut the perches off and weld on new ones
i would see if you can get a driveshaft made with cv joints for the front
88 gmc v3500 bonus cab classy chassy conversion, 454, nv4500, np205, dana 60 front with spool, 14 bolt ff cac rear with locker.
spencer_41188 is offline   Reply With Quote
Old 09-01-2012, 12:44 PM   #15
Redcap
For SALE.
Redcap is offline   Reply With Quote
