08-26-2012, 06:11 AM | #1 |
Lowering 62 c10 front end
How can I lower the front 2" without upgrading to spindles?
08-26-2012, 01:21 PM | #2 |
Who Me?
Re: Lowering 62 c10 front end
Loosen the tortion bar bolts and it will come right down. Just need a 15/16 socket and your on your way.
Steve 1997 Tahoe LT 4D 2WD (DD) 2001 Blazer 4D 2WD 1961 Apache 10 (sold) 1965 C10 Stepper (sold) |
08-26-2012, 07:10 PM | #3 |
Is that gonna mess with the alignment?
08-26-2012, 07:43 PM | #4 |
Who Me?
I have this setup the last two years with no issues.
08-26-2012, 07:59 PM | #5 |
Who Me?
The one drawback I found is the adjustment bolts become the lowest part of the truck. They may bottom out. Mine sit 4-5 inches off the ground and it's not really an issue. I do have bags in the rear if I need a little more clearance.
08-26-2012, 08:45 PM | #6 |
Alright thanks for the info
08-26-2012, 10:05 PM | #7 |
you can reindex the torsions so they arent the lowest part of the truck. make a paint mark where the torsions attach to the lca so you see where they were, then loosen them all the way, unbolt/pull them free of the lca, turn them "looser" a couple teeth, reinsert and bolt back together.
now when you turn them back in where they tuck up inside the frame, your truck will still be lower than before.
08-27-2012, 04:26 AM | #8 |
Do any of u have pics of the torsion bar? I was looking and couldnt find it so im thinking its not wat i thought it was
08-27-2012, 08:49 AM | #10 |
So its more under the cab?
08-27-2012, 10:03 AM | #11 |
Senior Car Nut
yes, the adjustment bolts are under the cab. if you're going to do this, please read up on the method and take the precautions. yes, it'll mess with the alignment, same as lowering springs or cut coils (for those of us with coil springs). it'll tilt the wheels in at the top, mine's been that way for years. I figure it helps me go around corners faster
Larry |
08-27-2012, 05:54 PM | #12 | |
1966 C10 short stepper KMHK |
08-27-2012, 07:18 PM | #13 | |
Who Me?
08-27-2012, 08:16 PM | #14 | |
08-28-2012, 06:32 PM | #15 |
Mine loosened pretty easy. I got it lowered a lil
08-29-2012, 04:13 PM | #16 |
Who Me?
Got some pics before and after?
08-29-2012, 06:40 PM | #17 | |
I havent found the picture I need of the splines on the front of the torsion bar, but if you mark them as they are, pull them out and turn them "up" a little, you will have to crank the adjuster tighter to get the same lowered stance as before, and it gets the adjusters off the ground. I did it all the time on imports.
08-29-2012, 07:37 PM | #18 |
Who Me?
Thats what I wanted to know too. On the rear of the bar its 6 sided, is the front the same or is it more like an axle spline?
08-29-2012, 10:43 PM | #19 | |
08-30-2012, 08:40 AM | #20 | |
Senior Car Nut
"install front hex of torsion bar into rear of torsion bar socket on lower control arm...." (1960 Chevrolet Truck Shop Manual) maybe the torsion bar socket has more sides
Larry |
08-30-2012, 10:17 AM | #21 |
If its hex and not spline, I think you could move the rear torsion key (looks like a pork chop) one hex flat higher and tighten it up all the way, should keep the drop and move the adjuster off the ground.
08-30-2012, 12:09 PM | #22 |
Is it possible for Joedoh to maybe write up a thread? I have a 60 and 2 years ago I installed 2 1/2 CPP dropped spindles.. last year I installed my new drive train and one side sits about 1 1/2" lower... Almost finished my truck but I havent driven it any where except in my property...I played with the torsion bar adjustment and cant get it to sit even...and yes my torsion bar bolt sits about 4 inches from the floor... Can any one of you kind folks please chime in??
CURRENT & PAST CHEVY TRUCKS 60 C-10 Apache short step side 62 C-10 short step side 66 GMC Long bed fleet side 305 V-6 77 C-20 Custom Deluxe (Blue Goose) |
08-30-2012, 04:11 PM | #23 |
Who Me?
That may work also and you wont have to remove the bar from the LCA..
Tags |
62 c10, lowering my truck |
