Old 08-31-2012, 12:13 AM   #1
doobiebro
doobiebro's Avatar
over flow tank
Hey guys I'm looking for ideas and pics of over flow tanks in your trucks...soon I will be needing one and I need it to go with my 3 core aluminum radiator ....don't want to spend to much $$ but would like it to look good under my hood whether its stainless steel, black or whatever...
CURRENT & PAST CHEVY TRUCKS
60 C-10 Apache short step side
62 C-10 short step side
66 GMC Long bed fleet side 305 V-6
77 C-20 Custom Deluxe (Blue Goose)
doobiebro is offline   Reply With Quote
Old 08-31-2012, 01:33 AM   #2
markeb01
Senior Enthusiast
markeb01's Avatar
Re: over flow tank
Here’s what I used for mine, it’s a black powder coated tank from Jegs. The part number is 555-51137. It is also available in polished aluminum.
It’s very compact and actually works. With the old street rod style vertical tank the radiator always had air in it and the tank was frequently empty. With the new bottle, the radiator is always kept full right to the bottom of the cap.
I don’t have a recent photo but here’s what the installation looked like before I removed the inner fenders:
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
Old 08-31-2012, 11:53 AM   #3
doobiebro
doobiebro's Avatar
Re: over flow tank
markeb01 looks good...yours looks far out, how is yours mounted? I will need to mount mine on the d/s (left of the radiator) because there is no room near my battery box...
Old 08-31-2012, 12:06 PM   #4
markeb01
Senior Enthusiast
markeb01's Avatar
Re: over flow tank
Yes mine is several inches away from the radiator support because it’s mounted to the electric fan attaching hardware. Also my washer bottle was too close to squeeze it in. If I didn’t have those items in the way it could be mounted directly to the radiator support. It’s very easy to install, having T-bolts that slide up and down in the extruded slot. This provides very flexible mounting adjustment.
Here’s what the mounting looks like in my truck. First is a side shot. The upper and lower attaching nuts can be seen to the left of the tank. I formed hard lines for both the inlet and outlet:
This is looking straight down from the top. The upper attaching nut can be seen near the center of the photo:
This close up almost shows the mounting slot, and the lower nut can be seen somewhat blurry directly below the upper nut:
And I remembered wrong about the mounting bolts. They aren’t T-bolts, they’re standard 1/4x20 bolts so you can use whatever length best fits your application. Here’s a rather crappy shot of the slot showing the upper bolt:
And now that you've pointed it out, it would look a lot better tucked in up against the radiator support. With the inner fenders out of the way I think I'll move the washer bottle over and move it next to the radiator. Thanks for the idea!
Old 08-31-2012, 02:44 PM   #5
doobiebro
doobiebro's Avatar
Re: over flow tank
Now I see how yours is mounted...mine will go in farther because my radiator mounting brackets mount flush on the radiator support....Thanks Markeb01..
Old 08-31-2012, 04:21 PM   #6
markeb01
Senior Enthusiast
markeb01's Avatar
Re: over flow tank
Also – here’s an earlier thread with a variety of ideas:
http://67-72chevytrucks.com/vboard/s...overflow+tanks
Old 08-31-2012, 09:21 PM   #7
64shortbox
64shortbox's Avatar
Re: over flow tank
Here's what I did. Over flow tank and windshield washer all built into one. Pick N Pull on 1/2 price weekend these were in a varity of Ford products. Full size trucks, Explorers, Mercury Cougars, etc., etc. It looked pretty crusty when I bought it. I used the Lowe's cheap version of CLR filled the over flow part with it full stength, let it sit over night then swabbed with a rag & a screw driver followed by a spray of Armorall and it looks new. not to mention it has a built in washer pump and now I have windshield squirters too. Oh, I also got the squirt nozzels off a full size Ford truck too. I had to do a little tweeking on them to get them to spray between the cowl vents and hit the windshield in the right spot but it worked out great for me. The cut of the over flow fits our inner fenders almost perfectly. I did have to move teh horn relay and the voltage regulator to the other side of the radiator support but I was able to use the exact same mounts & mounting holes so I didn't even have to drill any new holes for that part.
64shortbox is offline   Reply With Quote
Old 08-31-2012, 09:44 PM   #8
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
Re: over flow tank
Here's what I did.
Steve
1997 Tahoe LT 4D 2WD (DD)
2001 Blazer 4D 2WD
1961 Apache 10 (sold)
1965 C10 Stepper (sold)
61_FL_Apache is offline   Reply With Quote
Old 09-01-2012, 12:21 AM   #9
hopped up
hopped up's Avatar
Re: over flow tank
Here's what I did. I used an alluminnum water bottle I got for free from a place I eat lunch . And used a bike water bottle holder that I bought for a dollar at the swap meet. Cheap and effective!! And works perfectly!
[IMG][/IMG]
hopped up is offline   Reply With Quote
Old 09-02-2012, 01:49 AM   #10
doobiebro
doobiebro's Avatar
Re: over flow tank
Nice ideas guys... Thanks for all the responses...
Old 11-15-2012, 07:06 PM   #11
ChevyFreak60
ChevyFreak60's Avatar
Re: over flow tank
Anymore pics guys??
1960 Chevy Stepside 2wd
1966 Chevy Fleetside 2wd
1965 Chevy Suburban 2wd
1965 Chevy Fleetside 4X4
1960 Chevy Fleetside BBW 2wd
ChevyFreak60 is offline   Reply With Quote
Old 11-15-2012, 07:36 PM   #12
Billett
Billett's Avatar
Re: over flow tank
I'm just trying to decide which bottle of alcohol I'm going to use for mine haha. Your truck on the other hand looks a bit nicer. That black one from jegs looks good, and I'm pretty sure summit sells a nice chrome one.
Will
1968 C10 - Project Texa Go 6.0/4L80e
2003 Mitsubishi Lancer Evolution
2002 Ford Excursion 7.3L
2024 Toyota Sienna
Billett is offline   Reply With Quote
Old 11-15-2012, 09:30 PM   #13
1Bad62Pro/Street
"Where were you in '62?"
1Bad62Pro/Street's Avatar
Arrow Re: over flow tank
Radiator Overflow Canisters
http://67-72chevytrucks.com/vboard/s...d.php?t=474670
PROJECT: "FULL METAL YELLOW JACKET"
1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck
PROJECT: "FULL METAL YELLOW JACKET Build Thread
What Are You Workin' On? - 1Bad62ChevyPickup
PROJECT: "TYRANNORAMBLER REX"
1969 AMC Rambler American Nostalgia Pro/Street
Youtube Channel: Father Son Projects
Youtube Channel: 2TIMOTHY2FITHTEEN
"North and South Carolina Folks Click Here!"
(((( ~ I have Parts For Sale & Miscellaneous Stuff ~ ))))
"Well being as there's no other place around the place,
I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D.
1Bad62Pro/Street is offline   Reply With Quote
Old 11-15-2012, 10:19 PM   #14
LDO
LDO's Avatar
Re: over flow tank
The combo unit used by 64shortbox is available as a doorman part thru summit and prolly thru your LAPS as well.
LDO is offline   Reply With Quote
Old 03-27-2013, 01:36 PM   #15
argonaut
argonaut's Avatar
Re: over flow tank
64shortbox,
I thought your pictures look pretty nice, so I picked the same reservoir myself so I could play around with it. I like how it consolidates both radiator overflow and window washer fluid and has plenty of capacity and even looking like it fits in the space pretty well. I'd prefer to keep the washer fluid and pump in the engine bay, rather than passing back and forth into the cab too.
So anyway, I don't use an external voltage regulator, nor a remote mounted horn relay so those won't be a problem. But what I don't see in your pictures or your post is what you did with the horn. I thought maybe you came up with a slick relocation of that too. Can you share? Do you have any photos?
Thanks!
Jason M. @argonaut62
1972 K5 Blazer CST, Turquoise
1966 K20 Short Fleet Pickup, Big Ugly
1964 C10 Short Fleet, Gertrude
2001 Porsche 911 Carrera
1996 Ford Bronco XLT
1980 Jeep Wagoneer
2008 Honda CBR1000RR
2005 Honda RC51
1981 Honda CB750C
No dis-assemble Johnny Five! No dis-assemble!
argonaut is offline   Reply With Quote
Old 03-27-2013, 02:04 PM   #16
DesertCat
DesertCat's Avatar
Re: over flow tank
rubber hose, Corona bottle... ... take the rest of the day off
My build thread - Devastation and Reform http://67-72chevytrucks.com/vboard/s...d.php?t=567131
DesertCat is offline   Reply With Quote
Old 03-27-2013, 04:26 PM   #17
forestb
forestb's Avatar
Re: over flow tank
if you use a Mountain Dew bottle the color of the fluid would almost match.
forestb is offline   Reply With Quote
Old 03-30-2013, 08:25 PM   #18
williamsboys
williamsboys's Avatar
Re: over flow tank
How did u mount your rad without the top bracket?
Williamsboy
williamsboys is offline   Reply With Quote
Old 03-31-2013, 01:01 AM   #19
RockTonka
RockTonka's Avatar
Re: over flow tank
I wanted a shiny one...
1958 Chevy 1 ton dually 4X4 dump/flat bed
My build thread
1966 "Not-So-Original" Chevy Custom Trim Suburban
My Time-Killing Project Truck
1966 GMC Extended cab 1 1/4 ton 4X4
My Son's build thread
RockTonka is offline   Reply With Quote
Old 04-05-2013, 12:09 AM   #20
64shortbox
64shortbox's Avatar
Re: over flow tank
argonaut, Here's the pics you asked for. I grabbed a pair of horns off a 73 or so C-10 flattened the brackets (I might have had to drill new holes in the original mounting brackets to make them work - I just can't remember for sure) I used some factory mounting points to mount the horns. They cleared the cross support rods with no problems. For the horn relay I simply moved it to the other side of the radiator support and used the stock mounting points for it. Hope this info is of some help.
Old 04-05-2013, 12:23 AM   #21
64shortbox
64shortbox's Avatar
Re: over flow tank
One more pic of how I ran the over flow hose from the radiator to the copper tubing
Old 04-05-2013, 10:13 AM   #22
doobiebro
doobiebro's Avatar
Re: over flow tank
Sorry so late I missed this one......60-63 radiators I believe are mounted on the sides of the radiator to the core supports..
Old 02-19-2014, 04:31 PM   #23
doobiebro
doobiebro's Avatar
Re: over flow tank
Update!.. found me a coolant resevoir bottle from a Ford New Holland tractor.. Cut and fabbed mounting bracket and mounted it to a hole on the front lower battery box hold down assy.. I looks like it goes there.. sorry for the poor looking phone pics..
Old 02-19-2014, 04:44 PM   #24
1Bad62Pro/Street
Hey Bud,
I see you have a Champion Radiator. How do you like it?
Old 02-19-2014, 08:26 PM   #25
gofastnut
gofastnut's Avatar
Re: over flow tank
Doobie, I see you have a serpentine set-up on there. Is it a retrofit, or a newer engine?
Jeff
96 C3500 Crew Cab Long bed (Waiting on Cool Name)
64 C-10 shortie stepside, "Ole Brownie"
C-10 Club
My achingly slow build: http://67-72chevytrucks.com/vboard/s...d.php?t=508345
gofastnut is offline   Reply With Quote
