09-01-2012, 10:06 AM | #1 |
Rear Disk Conversion Parts Question ????
Has anybody ever 'sourced' the Levers and Springs for those 76-78 Caddy Eldorado rear disk brakes with the parking brake built in? I know you can get re-manu. calipers alone, but can we find the levers and springs to go with them?
Thanks. |
09-01-2012, 01:39 PM | #2 | |
Re: Rear Disk Conversion Parts Question ????
http://www.tsmmfg.com/3120.htm Other than that, junk yards. BTW: calipers from a Buick Electra also work. I'm using the buick caliper on the right side, and a caddy one on the left. That leaves both installed above the axle, as they should be. I'm using one from a 1978 caddy Seville on the left. Heres a pair ON CLEARANCE from RockAuto, AUTOSPECIALTY / KELSEY-HAYES, for $39.79 NO CORE CHARGE!! http://www.rockauto.com/catalog/rafr...ES409LT-198926 I'm just going to fabricate the spring mounts, if I can't find any.
......its not what your askin', its what your gettin'.... .......every time I screw up, I learn something. Needless to say, I'm learning all the time............ Last edited by biggestjohn; 09-01-2012 at 01:42 PM. Reason: mo |
