Old 09-01-2012, 04:42 PM   #1
68350
68350's Avatar
Sourcing a stall torque converter...
Anyone know a good place to buy a stall torque converter? I need a 2600-2800. Also, when I measured my fly wheel, from bolt hole to bolt hole(straight across) is 11". Is that what size I go by when I buy one. My 496 stroker transformation is well under way and this is one of the last things I need
68 Chevy CST/10, 50th Anniversary, 327/th400, 373 posi, buckets
68 GMC Shortbox Stepside, 402/th400, Tilt, Tach, Bucket Seats, 3.08 Positraction
69 Chevy Camaro SS, 383, 4 speed, positraction
70 Chevy El Camino SS396, Triple Black, 454/th400, Tach
70 Chevy Shortbox Stepside 4x4, 350/th350, Tilt, Tach, Cab Lights, Bumper Guards, Tow Hooks
70 Chevy 3/4 Longbox, 350/auto, 70k, SURVIVOR
71 Chevy Blazer, CST, 350/auto
71 GMC Sierra K2500, 454, 4 speed, 4.10 posi, 37s
71 Custom/30, Open Road, 350/th400, tilt
72 Chevy Shortbox Fleetside, 496 Stroker/th400, Tilt, Tach, Bucket Seats, 3.42 Posi
72 GMC Sierra Grande 2500. 427/th400, tilt, a/c, tool and stowage, buckets/console, 3.54 posi
68350 is offline   Reply With Quote
Old 09-01-2012, 07:44 PM   #2
hugger6933
Re: Sourcing a stall torque converter...
I loved the TCI converter I had behind the big-block in my old Chevelle. I live in Ar and they are made in MS so it is only a couple hunred miles so if I needed a change I could pull it and they could cut it open andtigthen or loosen depeneding on what you needed. But that was a race applacation. Anyway, the TCI stuff always worked good for me and they are willing to help you decide what is best for you and your truck depending on cam, compression, rear gear and total weight. Also don't forget to put a good cooler on the truck to help keep the trans happy. Jim
hugger6933 is offline   Reply With Quote
Old 09-01-2012, 09:21 PM   #3
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Uh... almost any aftermarket parts outlet? Jegs? Summit Racing? Even on ebay?
You will need the TC that fits your transmission.
Gary
'cuz chicks dig scars...
I would never rebuild a 305.
Old 09-01-2012, 09:38 PM   #4
fatgump
fatgump's Avatar
I called Hughes and they recommend this one for my specs. http://www.summitracing.com/parts/HUP-GM30/. Funny thing is they are in Arizona and I am in Arizona, but it was cheaper to buy from Summit.
fatgump is offline   Reply With Quote
Old 09-01-2012, 09:58 PM   #5
clinebarger
Thats a loose converter for such a big engine?
clinebarger is offline   Reply With Quote
Old 09-01-2012, 11:27 PM   #6
atomic67
Junior Member
Circle D torque converter. They will build what you need.
atomic67 is offline   Reply With Quote
