Old 09-02-2012, 08:09 AM   #1
86c20
86c20's Avatar
Re: idle screw on q-jet?
yes it is. it is right where the cable goes to the carb. also i dont know what cam you have but after a point they need more rpm to idle. one i had any less the 1000 it would fade out and stall
1986 c20 "the hillbilly" 350 sm465 3.42gears 21mpg at 70mph
1985 k30 "the ice cream truck from hell" no rust az truck
197-8??? c30 "ramp truck" 454
1978 monte carlo 350 350th with 2.73 gears. no rust. sc car
86c20 is offline   Reply With Quote
Old 09-02-2012, 10:18 AM   #2
Corts60
Just here to tinker
Corts60's Avatar
Umm, what rpm is it idling at now? Is the truck manual or auto? Either way, your idle should be no less than about 650-750. If you're around that rpm and it still doesn't sound lumpy then the cam you have is not that aggressive. That "lumpy" sound comes from valve overlap.
Old 09-02-2012, 03:10 PM   #3
wwj75c30
wwj75c30's Avatar
its auto. when its cold its at like 1k when it warms up its at like 5-600
wwj75c30 is offline   Reply With Quote
