09-02-2012, 08:51 PM | #1 |
What is this wire...
The green wire is bound together with the yellow one going to the coil... where is it supposed to go? Please help
"I taste Rust" I wish I had the money my truck thinks I do I taste "Patina" |
09-02-2012, 08:57 PM | #2 |
Re: What is this wire...
Temperature sending unit, usually installed near the front of the left head.
1971 GMC C2500 Custom Camper - Second Owner. 350/TH350, Dana 60 Rear. |
09-02-2012, 09:05 PM | #3 |
THANKS!!!!!!!!!!!!!!! That was fast
09-02-2012, 09:09 PM | #4 |
hmmmmmmmmmmm....
I think someone install something wrong
09-02-2012, 09:10 PM | #5 |
I would be thinking tach wire since it goes to the coil
09-02-2012, 09:12 PM | #6 |
20' Daredevil (Ret)
It looks similar to the horn wire.... but if it's run together with the coil wire, that's not it.
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay |
09-02-2012, 09:15 PM | #7 |
It looks like there is sender there, but it doesn't look like the correct one.
09-02-2012, 09:16 PM | #8 |
no tach on my dash, not that makes a difference. On the wiring harness it is with that coil wire. That 2 prong sender has me worried. It is similar to the horn wire, but i think the horn wire is heavier gauge.
09-02-2012, 09:18 PM | #9 |
Oh, what do you think of the PO's breathers? 1 on each side
09-02-2012, 09:29 PM | #10 |
They look more like "drippers" LOL.
If it is a green wire, in the engine harness with that loom and that connector, it goes here: It looks like you have the wrong sender in that head, it should look more like this:
09-02-2012, 09:35 PM | #11 |
Sweet! Thanks!!!
09-02-2012, 09:36 PM | #12 |
I hooked mine up today since it hasn't been hooked up since I got the truck and my temp gauge pegged out on the hot side. Plus someone in the past moved my temp sonsor from the front of the left head to the rear of the right head. Maybe I will just replace the sensor unless anyone has any other ideas.
-Scott- |
09-02-2012, 09:39 PM | #13 |
Moderator
the horn wire is also green, but comes off the headlight harness
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul |
09-02-2012, 09:43 PM | #14 | |
09-02-2012, 10:49 PM | #15 | |
Likely the heads were removed and not put back on the same sides as they were. Posted via Mobile Device |
09-02-2012, 11:01 PM | #16 |
I believe 73 up had the sensor in the rear of the right head
72 Cheyenne super 10 08 3500 HD 4dr dually 12 ford flex (wifes ride) 76 Monte Carlo 83 Chevy short wide Silverado 96 Mazda Miata, 2000 Allegro Bus |
