08-18-2012, 09:36 PM | #1 |
C10 Club Tennessee
Bagged Suburban Guys??
Where are you guys putting your tank and compressor at. Mine's been on schrader valves for a while and I'm about to install my Air Ride Technologies digital air gauge and sensors. Just trying to find the best place where it's not too loud.
Bryan www.gmtruckshow.com Project "Andes"-Halen's First Truck Project: Patina Burb for he is God’s servant for your good. But if you do wrong, be afraid, for he does not bear the sword in vain. For he is the servant of God, an avenger who carries out God’s wrath on the wrongdoer. Romans 13:4 |
08-18-2012, 09:39 PM | #2 |
What?
Re: Bagged Suburban Guys??
Check out the build area for the burbs, there are a couple builds in there that may help answer your question.
Chris 1968 K20 Suburban 1972 K10 LWB PU |
08-19-2012, 09:58 PM | #3 |
low n' slo
heres what i did with a 5 gallon tank.
[IMG][/IMG] little dusty...right now i have one comp but will be getting a dual pack before it hits the road. im going to make another bracket to hold 2 of them right where the single one is at now.. the tank bracket is (2) pieces of 2" square tubing welded togeter to raise it up..then its bolted to the frame. the cross plate is 3/16" plate that i bolted the air tank to. no way the tank would work with those brackets without raising it up..it barely clears now.
67 1/2 ton Suburban - Project DRGNWGN. Build thread -_--_--_ _________ _--_-_ -/____|__|__\__ ,.,,,.,.,,.,|_O _______ O_] Last edited by kev2809; 08-19-2012 at 10:07 PM. |
08-20-2012, 02:55 PM | #4 |
I mounted mine to the bottom of the rear floor between the gas tank and bumper.
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 Last edited by Hart_Rod; 08-20-2012 at 03:01 PM. |
08-20-2012, 03:06 PM | #5 |
low n' slo
are those pics with the truck laid out?
67 1/2 ton Suburban - Project DRGNWGN. Build thread -_--_--_ _________ _--_-_ -/____|__|__\__ ,.,,,.,.,,.,|_O _______ O_] |
08-20-2012, 06:04 PM | #6 |
Kev are you talking about my burb?
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
08-20-2012, 06:21 PM | #7 |
low n' slo
ya, just trying to reference how far that is from the ground when aired out.
08-20-2012, 07:06 PM | #8 |
Kev - it's probably 8" off the ground when aired out. I'll try to take some good pictures the next time I get a chance.
08-20-2012, 07:19 PM | #9 |
Here's the best I can do right now. it's not quite as low as it appears because I have the front on jack stands.
08-20-2012, 09:34 PM | #10 |
here is where i have mine mounted at. not exactly the quietest spot because i have the rear valves mounted directly to the tank, but then again my burb isnt exactly quiet anyways.... doesnt help that i dont have a rear floor lmao
but anyways its just another idea. oh! its a 9 gallon tank, and the rear valves will be getting relocated to below the rear floor once i build it. but the tank will most likely stay their. and if you want an idea where to mount the front valves this is where i have mine at |
08-21-2012, 07:18 AM | #11 |
C10 Club Tennessee
I ended up mounting the tank and compressor under the third door on the frame.
08-21-2012, 06:21 PM | #12 |
low n' slo
must have a skinny tank, mine wouldnt work there.
09-04-2012, 12:02 AM | #13 |
Might help...
My 72 Suburban Build - http://67-72chevytrucks.com/vboard/s...d.php?t=454019 79 Volvo Turbo LS Build - http://67-72chevytrucks.com/vboard/s...d.php?t=594252 Buggy Bed for son - http://67-72chevytrucks.com/vboard/s...d.php?t=657350 |
