#26 |
"brand new second-hand"
Re: What do you tow.
Back in the day when my grandparents owned the truck, they would tow a 34 foot RV trailer that I would guess to weigh 12,000 lbs. They would tow from San Bernardino to San Diego to the beach for the winter. This route has some good hills to climb-truck had a stock 350 w/ turbo 400 and 4:11 rear, a/c p/s,p/b customcamper20 with the optional overload spring. (now it has a 454 with the turbo 400 and 3:23 rear end). Frame mounted hitch
Steve 69 3/4t custom camper tilt,am/fm,speed warning,air gauge,buddy buckets,aux battery, big block,p/s,p/b,a/c 67 Camaro 96 Impala ss-sold 04 hybrid Honda-saving gas for the blue truck!:b69: |
#27 |
What do you all think of pulling a 10k pound (capacity) car trailer with a SWB using a frame mounted hitch with weight distribution hitch and obviously a brake controler?
Currently I use my '03 suburban for pulling duties, but have thought of putting a hitch on my 69. My big concern is the wheelbase, being relatively short for that kind of load. |
#28 |
Quit if it's not FUN!!!
Found this after I got home. Will this handle a 2000# camper behind my short stepper??
. Bolts to bottom of frame rails and bumper face behind tag. . I might even have it replated..... |
#29 |
Old member
I didn't build it to tow anything much but with a regular bumper hitch ball I do take the cart to shows with me every now and then. In fact next Saturday I'll have some new pictures of it towing the new cart to a show.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
#30 | |
Junior Member
Besides having a short wheel base the trailer will weigh quite a bit more than your truck. If you try it start out slow and see how things goes. Most of the time now we use my '92 K-3500 dually or his 2000 Z71 lwb. Nothing phases the dually, I have it set up for pulling large 5th wheel travel trailers. It does like gas stations though ![]() One thing that may help if you have the helper springs that are mounted behind the axle from the frame.
'67 Chevy C-20 short stepper - build complete, 454/SM-465. '75 C-30 Single Cab DRW-350 small block/NP-435. '77 GMC-6500 Dump Truck, 427 Tall Deck. '92 GMC K-3500 Duallie, 454/4L80E. |
#31 |
#32 | |
I do know that the newer jeep grand cherokees have a fairly high tow capacity and have a similar wheelbase and probably a little narrower. I also have a sway control setup I'd probably use too. Oh well, in reality I probably won't do it anyways...cause I have the suburban. |
#33 |
the boat guy
what do i tow? yikes i have one of those useless lowered 2wd swbs
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck 66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate. 28, model a rpu project, |
#34 | |
Nice. Great Thread OP. I plan to tow this once my 72 is back on the road. ![]() |
#35 |
That is pimp.
#36 |
Love the burn out. LOL.
#37 |
72 3/4 ton with leaf spring rear. mildly built 402 with th400 and 4:10 rear
#38 |
This the morning after I got home with the 72 Cheyenne.
#39 |
![]() Join Date: Aug 2011
What ever I can.
1927 Willy's Knight 24,000 original miles, 1958 Impala 283/Powerglide, 1964 C-30 383/4 speed, 1971 Monte Carlo 350/350, 1972 GMC K2500 350/350, 1976 Chev. K10 350/350, 2006 GMC Sierra 2500HD LBZ Duramax/Allison, 2006 Chev. Silverado K3500 LBZ Duramax/Allison |
#40 |
This until I rolled it in the median strip in Pine Bluff Arkansas. Now this. 68 C20 Custom camper with 2005 5.3 and a 68 Airstream Ambassador International. And my VTX 1800 in the bed.
![]() ![]() ![]() ![]() Been to Arizona, Mississippi, Louisianna... with em, No problems except the above pictured mishap. |
#41 |
my 68 from winter storage to my garage (the first meeting for the 68 with its new stablemate)
68 C10 LWB 2/4 drop 406/th400/3.73posi 04 Silverado SS LQ9 6.0/4L65e/4.11posi AWD |
#42 |
Junior Member
First time towing with my project. Bolted the bumper hitch I had laying around to Home Boy (4/7.5 drop). Hooked up my buddie's jet ski for the long weekend. We had to twist the safety chains quite a bit - and relocate the spare!
"I was patina when patina wasn't cool." 1973 Cheyenne SWB Sunset Gold / Frost White / Saddle |
#43 |
This is usually what the 71 Tows.
![]() I was just getting ready to raise the mast and prep the boat to cruise to Port Townsend from Seattle in this photo. Loaded and ready to go to Everett last month ![]() |
