Old 09-05-2012, 02:25 AM   #1
INSIDIOUS '86
INSIDIOUS '86's Avatar
Exclamation Urgent help! Th350 to th400
So we are swapping a th350 and 305 combo out for a 454 an th400. PROBLEM! Th400 had a bolt on yoke. It's from a suburban and the truck is a 81 shorty. What can we do about the driveshaft? It has to be cheap and quick though if possible
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 09-05-2012, 02:33 AM   #2
KQQL IT
At the body shop.
KQQL IT's Avatar
Re: Urgent help! Th350 to th400
Slip on goes on a bolt on style.
Old 09-05-2012, 02:57 AM   #3
INSIDIOUS '86
So what do we need? I know it needs slip in the driveshaft. The th350 is a long shaft trans and the th400 Is shorter.
Old 09-05-2012, 07:29 AM   #4
xrcr
Look at this and see if it helps http://www.maliburacing.com/auto_tranny_id.htm
You need to get a slip in yoke and have at least 1" in the tailshaft maybe 3/4 but I don't know. I put a 350 in a 4 speed truck using a driveshaft that was behind a 700r. had to change to a 9" tail on the 350
xrcr is offline   Reply With Quote
Old 09-05-2012, 08:41 AM   #5
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
I have always had long bed pickups . The driveshaft with a th400 was always a slip in like on the th350, however the shaft on a 400 was always a two piece. UNfortunately when you are customizing things, its never cheap or easy. IIRC the tailshaft on the th400 is either long or short tail much like the th 350. the short tail is the one with the bolt on driveshaft. the vast majority of the short tail ones were in vans and those van cab truck body trucks they make. Im thinking your only way out is to have a driveshaft custom made.. Also every th400 ive seen in the pickup has a carrier bearing that needs to be installed on the frame..
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 09-05-2012, 09:23 AM   #6
KQQL IT
At the body shop.
KQQL IT's Avatar
You will need a th400 slip yoke and a drive shaft shop to shorten the drive shaft and attach the new yoke.
Old 09-05-2012, 09:28 AM   #7
KQQL IT
At the body shop.
KQQL IT's Avatar
http://www.drivelinesnw.com/
Old 09-05-2012, 01:20 PM   #8
INSIDIOUS '86
Alright so I can either convert the trans to slip yoke or have a new driveshaft made basicly.
Can't gO two piece cause that will be too weak for a truck like this that will see track time
Old 09-05-2012, 01:22 PM   #9
INSIDIOUS '86
Also are you saying that a bolt yoke trans will take a slip yoke if we got a longer slip yoke to go in?
Old 09-05-2012, 01:55 PM   #10
KQQL IT
At the body shop.
KQQL IT's Avatar
Track time? Well the U joints will need to be 1330s if not 1350s. Which means a brand new shaft...
id guess a 305 t350 would be 1310 ujoints.
Old 09-06-2012, 01:52 AM   #11
Desert1957
Desert1957's Avatar
http://ls1tech.com/forums/automatic-...questions.html
http://www.chevelles.com/forums/show...put+shaft+yoke
This is the best web site I can give you, It list ALL the available yokes for 400 Turbos.
http://www.dennysdriveshaft.com/c8_t...lip_yokes.html
Desert
Desert1957 is offline   Reply With Quote
Old 09-06-2012, 02:19 AM   #12
Desert1957
Desert1957's Avatar
I think this is the one you need to replace a bolt on yoke, with the short output shaft splines on the tailshaft.
http://www.dennysdriveshaft.com/p108...ine_th400.html
Desert
Old 09-06-2012, 02:24 AM   #13
INSIDIOUS '86
Going to have my buddies at Drivelines nw build a driveshaft that will adapt to the trans. Eventually this th400 will be built for a 600hp bbc and have a gear vendor on it or he may go the 700r4 route. Either way we just need to get it moving though.
