Old 09-06-2012, 10:56 PM   #1
KINCAID
np 208 t/c leak
i have a 1970 chevy 4x4 short bed. i have a 700 r4 bolted to a sb 350 and a np 208 t/c. with a 4 inch lift. just had t/c rebuilt since it was leaking. i still have the same leak . it leaks where the tailshaft housing meets the case. is this a weak spot ? to much angle or pressure from rear drive shaft ? your help is greatly appreciated !!
KINCAID is offline   Reply With Quote
Old 09-07-2012, 09:35 AM   #2
Schralper
Schralper's Avatar
Re: np 208 t/c leak
Oh you poor fellow, a 700 & NP208, so sad.
Might wanna have a spare 700 around, especially if 33"+ tires.
The words POS come to mind when thinking of both of these.
The tailshaft seal will always leak, if you drive it.
The only t/c's that don't leak @ rear seal are fixed yoke.
Schralper is offline   Reply With Quote
Old 09-07-2012, 10:29 AM   #3
KINCAID
Re: np 208 t/c leak
ive not had any promblems out of 700 r4 this match up with np 208 was suppose to be the match up but im starting to think not is there a way to put the fixed yoke onto the 208 and why is this a promblem with these two together ?
