Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 09-07-2012, 06:17 PM   #1
spencer_41188
spencer_41188's Avatar
power adder
is it possable to run a roots type blower at 5psi on my 383 stroker with 11:1 compression ratio
all i wana do is make is a flat torque curve the hp it will make is just a bonus... its a 1 ton
dont wont nitrus and turbos cost more
88 gmc v3500 bonus cab classy chassy conversion, 454, nv4500, np205, dana 60 front with spool, 14 bolt ff cac rear with locker.
spencer_41188 is offline   Reply With Quote
Old 09-07-2012, 07:47 PM   #2
bubba353z
bubba353z's Avatar
Re: power adder
I foresee detonation and melted pistons if you do.....
Drop the compression and up the boost.
bubba353z is offline   Reply With Quote
Old 09-07-2012, 08:05 PM   #3
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: power adder
realistically, that compression is going to be an issue for you, unless you decide to run a different fuel type.
If you wanted to do it with a small 144 and your existing motor, it may be doable with a methanol kit so you can still run pump gas, but you might want to consult with a local tuner, as it would be a "potent" combo.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 09-07-2012, 10:14 PM   #4
Super73
Super73's Avatar
Re: power adder
You are in indiana. The corn fuel capitol of the world I have a buddy running upwards of 11-1 in a turbo application. But that is on e85, no meth, air to air intercooler and upwards of 25psi.
------Motor---------------Bottle
60'---1.53---------------1.41
1/8---6.58 @ 105.92----5.87 @ 118.41
1/4---10.38 @ 126.97----9.24 @ 142.49
Super73 is offline   Reply With Quote
Old 09-08-2012, 08:41 AM   #5
spencer_41188
Re: power adder
well the blower bolts right to the top of the engine and theres not many choices on intercoolers, water meth injection may be the cheapest way to go
if im gana change anything it would be the pistons because there hipercraptic lol but they sell crate engines with blowers and hiper pistons and comes with a 2 year Warranty and plus your paying out $11,000 for it ... it better be good
yes all the gas in indiana is e15 or e85
Old 09-20-2012, 02:00 PM   #6
GMR-PERFORMANCE
GMR-PERFORMANCE's Avatar
Re: power adder
Run E 85 and a simple meth kit is not over the top price wise.. as a back up just in case. But the e 85 is great.. make sure you have the correct items to work with that fuel though, its not very rubber friendly.
GMR-PERFORMANCE is offline   Reply With Quote
