09-07-2012, 12:53 PM | #1 |
Found a Fabtech 2wd lift kit and need some info
I am looking for someone that has had experience with these kits. I know they are no longer made for our trucks so there is very little info out there. I was at the wrecking yard and there was a 73 c10 with a Fabtech kit. The best I could tell the front only includes upper and lower tubular A arms and tie rod extenders. The rear just had 4 inch lift blocks. The info I need is that all the front lift kit consists of? Also how much lift should it be? I assume since this kit is only upper and lower control arms I assume it is more for looks. Lastly is this worth picking up? I can't see using it on any of my vehicles. I already have a 4x4 so don't need a lifted look vehicle.
09-08-2012, 03:59 AM | #2 |
Re: Found a Fabtech 2wd lift kit and need some info
The only one i know with a fabtech kit like that is http://67-72chevytrucks.com/vboard/s...d.php?t=282398 If it was me i would buy it if i could get it like 100 bucks or so and resell it on here or ebay.
