Old 09-03-2012, 03:11 PM   #26
JPBrecheisen
Re: 1962 GMC 4x4 Front Axle with disk brakes.
Originally Posted by Erl View Post
I have an original 63 front end. Send me a private message with your phone number.
Erl
PM Sent.
1960 GMC K1500 LB Fleet Side
1962 GMC K1000 LB Step Side
1988 Chevrolet C2500
JPBrecheisen is offline   Reply With Quote
Old 09-03-2012, 03:23 PM   #27
msgross
msgross's Avatar
Erl
gotta love the connections that you make on this board... tons of information and helpful friends...
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 09-03-2012, 06:13 PM   #28
JPBrecheisen
Agreed. Its nice to be a part of group of folks that all have a common interest. I'm still new to the forum, but so far I like it and its been a positive thing.
Old 09-03-2012, 06:17 PM   #29
JPBrecheisen
For those that are watching:
I got the ball repair done, and got some paint on it. The pics are not the best, but it turned out pretty well. Its humid right now so the paint is still drying, but should make a nice smooth surface for the new knuckle seals to ride on.
I picked up a cheap dig camera today, so hopefully I can post better quality pictures instead of using my beat up old phone.
Old 09-03-2012, 07:12 PM   #30
JPBrecheisen
Here is a better picture so you can see the repair. I posted the "before" picture as well so you can reference the improvement.
Old 09-09-2012, 02:07 PM   #31
j.kirn
ON stovebolt in the e-bay and craiglist finds there is a guy in california with a axle
j.kirn is offline   Reply With Quote
Old 09-12-2012, 09:44 PM   #32
JPBrecheisen
Thanks for the lead. I'll check it out. I had to make an extended trip out of town so progress is at a stand still until I get back. Still looking for parts, so I appreciate the tip
Jonathon
Old 11-26-2012, 03:22 PM   #33
47thriftmaster
47thriftmaster's Avatar
Nice work so far, should turn out nice even with the disc brakes. How about some pics of the truck as well?
47thriftmaster is offline   Reply With Quote
Old 04-06-2013, 01:02 AM   #34
JPBrecheisen
Been travelling a ton for work lately, but here is the update since its been forever. I aquired a spare closed knuckle from Erl in TX and should be pulling the brake parts off this weekend to clean up an install.
I wanted to make this truck original since it was so complete when I found it.
Old 04-06-2013, 01:09 AM   #35
JPBrecheisen
I missed the request for the pictures of the whole truck.
I have a few posted in the forum at other places, but here are a few of it that I have handy.
Jonathon
Old 04-06-2013, 11:16 AM   #36
'63GENIII
'63GENIII's Avatar
I like it JP! Hey is there any way to get a pic or two of that rear bumper? I think it may be the same as the one that I'm about to put on mine. BTW, I REALLY like the discs on the closed knuckle axle. Definitely not the easy way but very creative and keeps it close to original. Props to you on the hard work there.
Chris
'63 k15 long step
Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205
52" front and 63" rear spring swap
D44 / 14bff - disc axles
Milemarker 9K and 10.5K hydraulic winches
63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread
NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build
L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29
'63GENIII is offline   Reply With Quote
Old 04-07-2013, 12:26 AM   #37
JPBrecheisen
Here is the finished product with seal installed. If you look earlier in the thread you'll see where I did a repair on the axle housing area where the seal rides. It looks like its a nice smooth even surface again. Hopefully it will hold up well. It make smooth even contact like it should with no uneven spots or any binding.
Now I will work on getting the drum parts off of my spare axle and getting them cleaned up. I'll need to hunt down some brake hoses and shocks...those seem to be difficult to track down.
Old 04-07-2013, 12:34 AM   #38
JPBrecheisen
I can take some more specific pictures if you need. Here is a shot of the rear from the pics I have when I bought it.
Old 04-07-2013, 09:47 AM   #39
'63GENIII
'63GENIII's Avatar
Hey JP. Thanks for the pic. The bumper is almost identical. Sweet looking truck for sure!
Chris
'63 k15 long step
Old 04-07-2013, 11:09 AM   #40
JPBrecheisen
Did you need any more photos? I can take a few if you need them.
I have seen a few like this one except not with the extra holes for the lights this one has.
Let me know, I'll be glad to snap a few if you need it.
Old 04-07-2013, 12:15 PM   #41
JPBrecheisen
For those following along, I wanted to add this information.
I posted some comments and pictures on a thread started by danw210 as he was having similar issues.
When installing the disk brake spindles, you'll find they have a bearing to support the outer axle stub vs the bronze bushing that is original equipment (to my knowledge) for closed knuckle drum brake equipped axles. The I.D. of this bearing is slightly smaller than the I.D. of the bronze bushing. This will cause issues as the outer axel stub won't fit inside the spindle bearing.
What can be done is turning the bushing/bearing surface of the outer stub down a smidge so it will fit inside the spindle with bearing.
I located an extra set of outer axle stubs and had them machined to fit the later model spindle with bearing.
As you can see, it fits onto the axle with no issue.
Old 05-13-2013, 12:31 AM   #42
JPBrecheisen
Got the wheel hub reassembled and installed along with the drum brakes. I couldn't have gotten it to this point without that front axle I picked up. So far, so good. Now for the other side....
Old 05-13-2013, 02:22 AM   #43
JPBrecheisen
Also got my slot mags cleaned up and my new tires installed...I think they look pretty good.....I hate how messy my garage looks in these pictures
Old 05-17-2013, 06:26 PM   #44
bhc41051
bhc41051's Avatar
Hey JP, I'm replacing the front brakes on my 62 K10. Did you buy new springs or did you use the ones that came with drum brake set up off the 63? My top spring doesn't seem tight enough...
bhc41051 is offline   Reply With Quote
Old 05-17-2013, 09:40 PM   #45
JPBrecheisen
I replaced them. I think you might be able to get them from a normal auto parts supplier, but they are the same springs that are used on the 11x2 front drum brakes on a willys jeep and are available from Walcks 4wd.
Here are the ones you should need.
http://walcks4wd.com/top-shoe-spring.html
http://walcks4wd.com/lower-shoe-spring.html
The other thing about these drum brakes that can kinda mess you up is that the brake shoe with the longer lining goes towards the front of the vehicle because they are non-servo brakes. More modern drum brakes are the opposite.
You can use the picture I have posted as a model and you should be ok. Mine are installed per the 1962 maintenance manual. Take a look at where the yellow spring connects to the brake shoes as well. That is how the book says to attach it.
So...longer lining towards the front...and the long end of the spring goes in the round hole on the front shoe while the short end of the spring goes in the slotted hole in the rear shoe.
I hope this helps.
I am travelling overseas, so if i don't get back on for a few days, thats why
Jonathon
Old 05-17-2013, 11:51 PM   #46
bhc41051
bhc41051's Avatar
Thank you very much Jonathon, You were right I had my primary and secondary shoes switched around, and my spring was in the first slotted hole instead of the round one.. I did figure out the Jeep parts, I bought my springs and those clips that hold the shoes in place from kaiserwillys.com.. I should be good to go now. I removed my drivers side brakes before I realized someone had robbed the shoes and hardware from the passenger side. So I really didn't have much to go by when it came time to put everything back together..
I'd love to find one of those yellow Spicer Hub tags.. very cool!
Old 05-19-2013, 10:02 PM   #47
JPBrecheisen
No problem, glad I could help. When I took mine apart, the shoes were backwards also. I didn't think anything of it until i read the book and talked to a few Willys/Jeeps folks about how to correctly install them.
Glad you found the parts ok.
I am not sure if the "spicer joint" tags were used on the GM truck or not. I know for sure they were used on the Willys/Jeeps with the closed knuckle model 25/27 front axles. I guess they had to use those because the Willys/Jeeps used different types of front axle joints over the years (spicer cardan cross vs rzeppa etc). I am not sure if the GM/FORD truck ever used anything besides the spicer cardan cross type joint. I was told they used to tag the front knuckles on the Willys/Jeeps so when they cam in for service, the mechanic knew what they had without having to disassemble it first. If you wanted to find a set of tags, you might be able to find them on an old model 25/27 closed knuckle. I didn't even know mine where there until I cleaned off the knuckles.
Good luck with your project, let me know if there is anything else you think I can help with.
Jonathon
Old 09-12-2013, 09:33 PM   #48
JPBrecheisen
Been a while since I've been on to update. I got the passenger side all put together. Working on the drivers side. I'm going to stay with the original style drums but will probably make the upgrade to power brakes. The previous owner installed a dual master cylinder with booster, so I think the drums with the power assist will stop it just fine. I hope I can get some time to finish the drivers side up so I can check it out.
I also had LARES CORP rebuild the steering gear. From what I have found, they only used this style steering gear from 1960-62. I have some references that say they used it until 1963, but I think that was the switch-over year. I gained a 1963 front axle from another guy, but it had the later model gear on it. I only have found one extra steering gear like this one. I think its a bit of a unicorn. I'm glad this one was good enough to rebuild.
Last edited by JPBrecheisen; 09-12-2013 at 09:36 PM. Reason: forgot to talk about steering gear
Old 09-12-2013, 10:39 PM   #49
swamp rat
swamp rat's Avatar
Lookin good!
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 09-12-2013, 10:41 PM   #50
vectorit
What?
vectorit's Avatar
Nice!
Chris
1968 K20 Suburban
1972 K10 LWB PU
vectorit is offline   Reply With Quote
