Re: Rebuild or run it?
When a 4L60E/4L65E has aluminum & steel in the pan...Its BAD.
4L65E's are rare, And 99% are for AWD trucks, Finding a 2WD in a yard is next to impossible. If there is any way to get your money back...Do it! |
#2 | |
Registered Cruiser
Are you saying I won't be able to use this in my 2wd?
77' Chevy SB Dropmembered Front and Rear 5.3/4l60e combo |
Registered Cruiser
I can grab a couple.... give me a sec
Registered Cruiser
Snapped a couple pics... I was told '05 2wd, but I was also told the trans had 45K miles
#6 | |
And the only differences from the 60e to the 65e is * Five-pinion gears for input and reaction gearsets (versus four-pinion gears in the L60) * Heat-treated stator shaft splines * Induction hardened turbine shaft * Heavier-duty low/reverse roller clutch * Additional friction plate added to 3-4 clutch (seven plates versus six in L60) * Shot-peened output shaft * Revised valve body calibration
1985 K10 Under Severe Reconstructive Surgery 5.3/New Paint/New Interior/Yadda Yadda Yadda |
Registered Cruiser
Glad you find humor in my "toasted" transmission!
Lol. No humor found. I know all too well of paying a premium for "good" parts and finding out all is not as it seems.
Registered Cruiser
I know AJ, I laughed at myself for actually thinking I was going to run a trans I picked up for a couple hundred bucks. I don't have that kind of luck!
#10 | |
![]() But there's always that hope!
Registered Cruiser
What kind of estimated cost can I be looking at with the transgo kit included?
Registered Cruiser
Ok, 2wd, good. I was 99% sure it was 2wd, just from the pics of 4wd's I've seen. So looks like I will take it down to a shop for rebuild. Kinda of planned on it, in the back of my mind
The 2wd SS & Vortec Max were only made for 2 1/2 years, And were not high production vehicles.
