Old 09-09-2012, 10:18 PM   #76
VA72C10
VA72C10
VA72C10's Avatar
Re: Project#2 67-72 Restoration's Shop truck
Here it is with a real bumper . And painting the rear bumper. If I go chrome in the front this will be painted black. Last picture shows after I touched up the scratches...
If I stay white I will patina the rear bumper...why I primered rust color under even though it was already painted...
Old 09-09-2012, 10:23 PM   #77
67c10rustbuket
67c10rustbuket's Avatar
Looks good jonathan, I removed my manual trans xmember with the cab bolted on but I did have an air chisel. The hard part was slicing the rivet heads. I had to use a dremel in the hard to reach areas and the slice the heads off with the air chisel and change to a punch bit to drive them out (at an angle). Then sliced the xmember in half with a sawsall to make it easier to remove. It was not fun bit I got it out. I dont know if yours was a 6? but I think they mounted back farther back one hole making it even more of a pain!
Dan <---(my name)
67 SWB C10 project "GEORGIA"-59 Brookwood 2dr wag...Next project-03 Tahoe 4x4 5.3 family ride-07 Hondur Accord, commuter car
67c10rustbuket is offline   Reply With Quote
Old 09-09-2012, 10:25 PM   #78
VA72C10
VA72C10
VA72C10's Avatar
Here is my wife holding up the chome bumper after I had set it up there for her to look at...and I stuck the headlight bezels on for a rough idea....of course id paint the recessed areas black and put the aluminum grill hoops on
Old 09-09-2012, 10:30 PM   #79
VA72C10
VA72C10
VA72C10's Avatar
Thanks for the info and pics; but mine is a 67 so it's under the cab at the back rivets...that and I will need to dimple the frame when I add power steering.....
Old 09-09-2012, 10:42 PM   #80
VA72C10
VA72C10
VA72C10's Avatar
My 5 and 7 yr olds wanted to "help" so I let them hand things to me and they also helped clean up my tools at the end...
After 10 minutes they wanted to play in the backyard so I decided to tackle a project I need to do at some point so I could watch them and swing them fro time to time. Using the 307 rear out of my 70 since it has new wheel cylinders, brakes, and main brake line. Got the rear mostly out and the rear bumper off finally after soaking the bolts in pb blaster a few times...
The spring pocket bolts are really bad so I might end up cutting the spring to get that out....going to soak them and then heat them as one last try since the springs aren't sagging and I could get 40 or 50 bucks for them
Old 09-09-2012, 10:48 PM   #81
VA72C10
VA72C10
VA72C10's Avatar
Final pics today show some of my favorite patina. (And why you don't wash a truck in the dark
Old 09-09-2012, 11:00 PM   #82
Rusbuilt
Rusbuilt's Avatar
Progress! I like the white bumper for the patina!
Rusbuilt is offline   Reply With Quote
Old 09-09-2012, 11:37 PM   #83
1972BackInBlackC10
1972BackInBlackC10's Avatar
looking better and better, i like the white patina parts vs the chrome ones imo they suite the truck better than the chrome, but its your truck
1972BackInBlackC10 is offline   Reply With Quote
Old 09-10-2012, 02:49 AM   #84
NewType72
NewType72's Avatar
White patina'd parts for sure and make sure to do the inner grill hoops same. My apologies to the wife but this may help for reference..
also here is the other odd custom touch rear window covering I was speaking of with push buttons all around the window frame
Project NewType 1972 Chevy C/10 Cheyenne Super ( Daily Driven Showtruck ) http://67-72chevytrucks.com/vboard/s...d.php?t=507903
Project Great Grandpa's Legacy 1973 Chevy C/10 Cheyenne ( Current daily driver collecting big time parts ) http://67-72chevytrucks.com/vboard/s...89#post7084289
- Dylan
(209)-985-7721
NewType72 is offline   Reply With Quote
Old 09-10-2012, 05:51 AM   #85
XxCHEVYMANxX
XxCHEVYMANxX's Avatar
Nice progress ! and even though theirs something to be said about keeping the wife happy, I'm with the majority on the white bumpers.
John
Mild Custom 68' Work Truck Build
Facebook LoL
1977 Trans Am (Project)
1965 Chevelle (Project)
XxCHEVYMANxX is offline   Reply With Quote
Old 09-10-2012, 07:02 AM   #86
brn agn
brn agn's Avatar
My vote is for white too...but I'm partial.
What wheels are on the frame in your backyard?
1969 C10 SWB Project Charity Case AKA "Roscoe"
1971 Cheyenne Super A Combined Effort
The Service Station-A practical ministry for those in need
brn agn is offline   Reply With Quote
Old 09-10-2012, 04:04 PM   #87
VA72C10
VA72C10
VA72C10's Avatar
Thanks everyone. White it is! I'm going to keep an eye out for a 67-70 bumper with better patina than the one on it now...
My wife said she didn't like the color white or the way I painted over the scratches which I agre with her on that so when I find a better patina'd front I'll swap out...
Found a mirror box id bought off the forum a while back....one of the mirror arms happens to match the truck almost perfectly....just need to find a mirror head that's got a patina'd white back...
Truck came with this mirror style obviously and thankfully the screws are still in the door even!
Old 09-10-2012, 04:43 PM   #88
brn agn
brn agn's Avatar
I'm not a fan of making patina, but this situation is different. Do you think you could get the desired results if you painted, then scuffed up your current white front bumper?
Old 09-10-2012, 05:20 PM   #89
doubleb's69
doubleb's69's Avatar
Very cool rig. I have some Chevy "COPO" poverty caps I would be willing to let go of if you were interested. They have some dings but that adds to the look.
Bud
doubleb's69 is offline   Reply With Quote
Old 09-10-2012, 06:09 PM   #90
VA72C10
VA72C10
VA72C10's Avatar
I'm the same way...only a few fauxtina jobs out there that I like...I might do that on this one (thinking of spraying the rust primer in spots and then crackle paint over that to mimic the look of the tailgate letters.... but first will try to locate one....I have an about 100pt checklist to get this thing on the road...the bumper can be later
Old 09-10-2012, 06:09 PM   #91
VA72C10
VA72C10
VA72C10's Avatar
Thanks! Any pictures of the caps? And price?
Old 09-10-2012, 06:51 PM   #92
68 Four on the Floor
68 Four on the Floor's Avatar
What if you blasted the bumpers and trim and painted them satin white?
68 Four on the Floor is offline   Reply With Quote
Old 09-10-2012, 07:09 PM   #93
VA72C10
VA72C10
VA72C10's Avatar
I thought about that but want to keep them matching the white on the roof with some patina....I might go pretty paint in satin or semigloss like brnagn and some others have done but really think I want the bumpers to look 45 years old too (and the hoops/bezels already have a great patina!
Old 09-10-2012, 09:48 PM   #94
doubleb's69
I'll try to get you some pics tomorrow.
Bud
Old 09-11-2012, 12:22 AM   #95
midniteblues
midniteblues's Avatar
I like where your going with this build you could say "keepin it real"
question though is the bumper on the back of the truck a factory bumper?
I'm on the hunt for a rear bumper for my stepper and dont wanna use a sport bumper.
I would love too have one of them big ole rear step bumpers but there tough to find any good.
I must say thats the first one I seen like that.
81 camaro 355 4/spd 342 posi my first love.
67 swb step 454/4spd ott 373 posi 4/7 drop.
2000 s10 zr2 little blue truck that never gets stuck.
'74 heald super bronc vt8. tecumseh powered moon rover.
midniteblues is offline   Reply With Quote
Old 09-11-2012, 05:27 AM   #96
ZUBZ
ZUBZ's Avatar
Nice thread, nice truck and I like it with the original bumpers.... looks good.
ZUBZ is offline   Reply With Quote
Old 09-11-2012, 02:32 PM   #97
VA72C10
VA72C10
VA72C10's Avatar
Thanks!
Thanks! 99% sure this is a dealer option...I've seen several that looked like this. It appears it came from the factory with no bumper...just noticed the license plate holder for trucks with no bumper....still on the truck...
If I find a factory sport bumper in white with patina and a hidden hitch for a good deal this bumper will be up for sale...I'll keep you in mind first if you're interested...
Thanks! Looking for a painted white rear sport bumper and a hidden hitch eventually...
Old 09-11-2012, 04:04 PM   #98
ultrahd4me
ultrahd4me's Avatar
Good find on that rear painted sport bumper. I've been looking local for 2 months for a nice patina white bumper, no luck here in the Nashville area. Hell I can't even find a chrome, sport, or a step bumper for a stepside. I think I'm going to just order a new raw bumper from Top Banana and just patina it myself and forget all the chasing parts. I've spent more in fuel than what the damn bumper cost new.
ultrahd4me is offline   Reply With Quote
Old 09-11-2012, 04:17 PM   #99
VA72C10
VA72C10
VA72C10's Avatar
I'm actually still looking for one . No hurry as this one will work until I find one
Here's a picture of the bumper and some painted caps I have as garage art (wrong yr and just losely placed on there for the picture)....note the license plate to keep the homeowner's association and local code enforcers off my back as I work on it
Old 09-11-2012, 04:26 PM   #100
Chvy2NV
looking good man!
Chvy2NV is offline   Reply With Quote
