Old 10-12-2003, 06:24 PM   #1
Scrub
Collector of rusty Items
Scrub's Avatar
Electrolosis eating heater core?
Off 67 72 topic,
I am posting this here cuz you guys:
Rock,
know stufff,
Answer posts
Plus no buddy knows me at the 94 - 98 board.
My buddy has a 94 burb and the heater cores just rot out of it. Both front and rear went out, so he bought a new one and it lasted 3 months. He took it back and they gave him a new one, but the guy told him an electrical short was eating the aluminum cores....
Anyone ever heard of such a thing? The battery has one of those battery buddy things that disconects the battery if there is any batery drain and it isn't going off, so I am doubting this story.
I'm thinking his water has something in it that is caustic. Can you get Non-aluminum heater cores? any advice?
Thanks in advance.
Scrub
Sisters, Oregon - Home of the Sisters Rodeo.
70 GMC 1,000,000 + miles
72 K-20 project, 456 Dana60 front, Corp14 rear w/locker, 265R19.5 tires 20-ply. Warn 12k winches both ends, Cross-over steering with raised tie-rod, Powerbox steering, 4500 watt 120-AC power, Air, Hydraulic aux power, 4 inch lift, 5000 lb air-bags both ends.
Scrub is offline   Reply With Quote
Old 10-12-2003, 06:29 PM   #2
lukecp
Formerly yellow72custom
lukecp's Avatar
http://users.eastlink.ca/~pspencer/n...ctrolysis.html
Yes....it could be the problem. You would have to have a positive source of electricity in your coolant though.
I bought a heater core for my truck from O'Reilly's and it was made out of the same metal as my radiator.
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride.
'70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck.
'97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg
lukecp is offline   Reply With Quote
Old 10-12-2003, 07:27 PM   #3
passthebuck
Sisyphus was my mentor!
passthebuck's Avatar
ok-back to highskool chemistry. aluminum is more reactive than iron & steel. Aluminum is the most reactive metal in the cooling system SO it gets attacked first by the acidic coolant. Coolant becomes acidic over time due to its rust inhibitors & the like breaking down. I had a similar problem - my aluminum thermostat housing was being eaten away SO I bought a MOTORAD radcap that hangs a piece of magnesium down into the coolant. Magnesium is MORE reactive than aluminum so it gets eaten first. The magnesium is called a sacrificial anode & it works. One could even do the same thing by throwing a pebble-sized hunk of magnesium down the neck of their radiator once or twice a year BUT you couldnt monitor how fast the anode is being eaten... A cheap source of magnesium are some old lawnmower decks (cast magnesium). Check out this link i found:
http://www.team.net/html_arc/datsun-.../msg00807.html
I know they're talkin about Datsuns BUT it is relevant to us too.
passthebuck
#5642
-TWO 1967 GMC 910's. One with L6/3-on-the tree and the other with 355 w/435hp & a 700r4.
-a 2013 Honda Civic as my "sensible" car
passthebuck is offline   Reply With Quote
Old 10-12-2003, 07:34 PM   #4
jamis
F.A.S.T. president
jamis's Avatar
you can buy Zinc anode at a marine supply store that will screw into the intake manifold. As far as ectrolysis goes you might have a poor ground to the engine and body. That would charge the coolant and it would look for any ground it can find. It could also be cheap coolant.
jamis is offline   Reply With Quote
Old 10-12-2003, 10:34 PM   #5
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Take a volt meter, and dip the positive lead into the coolant, and then the negitave lead onto the neg battery post. I think it is supposed to be under.5 volt. If higher, then flush and fill with new coolant.
And while chainging coolant, this would be a good time to get rid of that dex cool crap.
