ticking noise from 01 z71
a few weeks or so ago my 01 silverado with a 5.3l started to make a weird ticking noise, it only does it at speeds above 50 or so and i can only here it when passing a wall or concrete barrier on the freeway with the window down. rpm does not seem to change the noise but speed does. has anyone had this problem. i dont think its the motor but worried it could be from the tranny, its got aboyt 125k on it.
68 swb fleet bagged on 20's 327 with 4 speed http://67-72chevytrucks.com/vboard/s...d.php?t=223308 2014 Chevy 2500hd duramax CCLB |
![]() Join Date: Nov 2004
Re: ticking noise from 01 z71
Look at the exhaust manifolds, especially on the driver's side, and look for a missing bolt head. The one at the back by the firewall is notorious for snapping off on these trucks.
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride ![]() American Born, Country by the Grace of God ![]() 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
![]() Join Date: Jan 2003
Check the ujoints.
2013 Ford F150 FX4 2006 Chevy Silverado 1500 1982 Chevy C1500 2020 Ford Explorer Limited 2008 Ford Escape |
That sounds like a U joint to me too. When my U joint went out it was making a ticking noise.
2000 Chevrolet Silverado Z71 ![]() 1965 Chevy C-10 on '61 Apache Frame [90s Build] 1997 3500 Chevrolet Custom Mega Cab Project My son's '92/'93/'94 GMC K2500 Conversion Project |
sweet thanks! ill throw it on the lift tomorow and check all that!
checked my u joints and they are in good shape, i heard the noise again today and put the truck in N and didnt change it, it almost sounds like there is a rock in the tire but i only here it at freeway speeds and ony after its been at that speed for a few miles.
I had a car do that one time and it was a trim ring on the rim.
2001 GMC 2WD, 1998 Chevy K2500 |
could my u joints be bad but not have movement?
i replaced the u joints today and there was no change, i was able to get up to speed to make the noise and put the truck in neutral and shut shut the engine off and it still made the noise, does any one have any other ideas???
![]() Join Date: Sep 2005
is it 4x4? the transer case could be going bad
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2015 toyota Tacoma Daily 2012 Subura outback 2000 Tahoe 5.3l 420k 1999 honda accord General manager for Marco's Carwash & lube |
Also check for missing brake hardware...A loose pad can cause clicking noises.
yes its a 4x4, iv checked all the brake hardware and its all good.
i guess ill take it to my tranny guy and have him look at the t case
i got the truck up on the rack today and ran it to about 60mph in the air, i heard the noise and was able to track it to the t-case, i changed the fluid and that seemed to quiet it down but it is still there, would you guys reccomend having the transfer case rebuilt or just buy a new one?
#14 | |
Buying a NEW unit is Very expensive or impossible, Depending if you transfer case is still in production. |
#15 |
Took the t-case out today and to the tranny shop. He tore it apart and says that everything is fine. No loose chain or anything... Now I'm really stumped.
| Bookmarks |
