Old 10-11-2003, 11:29 PM   #1
bigjimzlll
bigjimzlll's Avatar
dash board weight?
How much does the stock dash..gauges and heater..dash pad..the whole shebang weigh????
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications
click the clicky to join the site....
http://67-72chevytrucks.com/vboard/payments.php
67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44
Anderson,CA
bigjimzlll is offline   Reply With Quote
Old 10-12-2003, 09:41 AM   #2
72MARIO
72MARIO's Avatar
Why ?
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 10-12-2003, 09:56 AM   #3
bigjimzlll
bigjimzlll's Avatar
Im pulling mine out to put a cage in. and if its heavy enuf..IE 75+lbs I will leave it out and do a sheet metal(aluminum dash)
Anderson,CA
Old 10-12-2003, 11:33 AM   #4
crazy longhorn
Fabricate till you "puke"
if you are pulling dash heater & all, my guess is that you could shave 75-100 lbs. I never did weigh the heater stuff that I pulled from the longhorn, & would be interested to know exact weight if you do check it.....crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 10-12-2003, 08:44 PM   #5
70c10
67-72 Addict!
70c10's Avatar
Wow Jim, next come the wheel tubs!
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 10-12-2003, 11:05 PM   #6
cableguy0
i would think maybe 75 pounds including the wiper motor heater controls and all i know the cab itself is damn heavy at 560 pounds with just front glass stripped and no doors but i would think with as thin as the sheet metal is in the dash that it really isnt gonna make that big of a difference
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
