Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 09-13-2012, 08:51 AM   #1
bigboybodry
bigboybodry's Avatar
Re: Almost back together
She is making noise. Have a ADRA race friday night Truck is ready!!!
If Rich doesn't tech I'll go off the stop again and see if the machnist 'trick' valve job helps or hurts LO. Has just a touch more compression (from milling the heads now 13.7 instead of 13.5). Because I'm not spinning it up and the convertor is a bit tight,, I put 1.5 more degrees advance in the cam this time.
Now just have to make 3 races and it will be Dune season again.
can't wait to see some video!
first track pass with the new motor on motor http://youtu.be/YgrJaEF_TaQ
bigboybodry is offline   Reply With Quote
