Old 09-13-2012, 12:21 AM   #1
McCoyAZ
McCoyAZ's Avatar
FORD oil filter on a chevy 283?
My old 283 has a Ford spin on long oil filter installed on it and I am wondering why?
I bought the filter called for in the parts book for a chevrolet 1964 vintage and it does not fit.
I had to buy one for a Ford.....
What's up with that?
McCoyAZ is offline   Reply With Quote
Old 09-13-2012, 01:01 AM   #2
ray_mcavoy
Re: FORD oil filter on a chevy 283?
Sounds like someone has installed a spin-on filter conversion kit on your engine. It originally would have had a cartridge type filter inside a re-useable metal canister.
And I believe there are two types of spin-on conversion kits available. One style keeps the original bypass valve that bolts to the block and uses a newer Chevy style spin-on filter. The other style (like you have) eliminates the bypass valve and takes a Ford style spin-on filter that has the bypass valve inside the filter.
ray_mcavoy is offline   Reply With Quote
Old 09-13-2012, 01:03 AM   #3
markeb01
Senior Enthusiast
markeb01's Avatar
Years ago I added one of those adapters to my very first 283 V8, and it also used a Ford filter.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
Old 09-13-2012, 07:42 AM   #4
aerotruk63
Check The Champ, Demonstrator
aerotruk63's Avatar
Had one on the 64 GMC I had with a 327. Bought the Chevy adapter to set things straight.
Old 09-13-2012, 11:42 PM   #5
Captainfab
60-66 Nut
All the Chevy V-8's built prior to '68 used a canister oil filter. Most of the cansiter to spin on adapters use a Ford filter.
