09-10-2012, 10:19 AM | #26 | |
Re: Pancaked Xmember Question
1966 C10 short stepper KMHK |
09-10-2012, 10:29 AM | #27 |
09-10-2012, 10:46 AM | #28 | |
Hollister, CA.
This procedure was not hard at all, and very basic actually. But I can see for some, this might be a large task. Yours looks like it came out good. Whether you drop cup or step the LCA's, your still gonna have that hanging crossmember or LCA. For the person who wants a small drop/rake....then I would say "no, you probably wont need this" However, if you want a low slung body, are not ready for bags, and do not want to make contact with that manhole cover down the street.....you might wanna go this route..... Posted via Mobile Device Posted via Mobile Device
John What the Heck is that ?? CURRENT BUILDS: 62 BurbMaster Other Builds: My '63 C-10,LWB,CC,BBW '06 HD StrAight Axle Swap Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build AMERICAN CUSTOMS & CLASSICS (831) 630-1965 www.ACCHOLLISTER.com ACC on FACEBOOK "Rest in Peace, Mom & Dad ... I will see you again someday!" |
09-10-2012, 11:16 AM | #29 | |
09-10-2012, 11:50 AM | #30 |
Another real option to consider is Z'ing the chassis. There are a few advantages to this method versus other methods, but it'll require very precise measurements and good fabrication skills to do it correctly. If you properly plan out the mod, the actual work is pretty simple.
Z'ing Pros: 4 cuts (2 rear/ 2 front) The factory steering geometry does not change You can easily move the wheels 1" forward to center them in the openings No steering clearance issues No drilling/ elongating holes on the crossmember Many more options on height (you can "Z" almost any height you wish) Provides a real lowering option (can run stock coils and spindles, if you want) Inexpensive Cons: Requires good measuring and fab skills Need to build a jig to hold the frame rails and front frame horns in position Need to adress the motor mounts if you want the engine to remain in the stock position You have to trim the inner fenders for clearance Sectioning the Crossmember Pros: No major frame cuts Good info on-line (i.e: Capt Chaos's pictures, etc) Can go back to a stock crossmember if you wish Inexpensive Cons: Requires a lot of cutting and welding on the crossmember Requires redrilling the holes on the side of the framerails Makes it more difficult to access the alignment bolts during front-end alignment If you want to move the wheels 1" forward, you have to redrill the frame Can only go 1.5" before steering linkage clearance becomes an issue Must move steering box up accordingly to eliminate potential bump steer condition You may have to notch the driver's upper control arm for steering rod clearance Each method has it's pros and cons. A lot of guys don't like the "Z" method because once you've cut the frame and the entire section is loose, you are 100% committed. With the crossmember method, you can do the work on a spare crossmember, and always have an option to put your stock unit back in. Some members have suggested a little bit of both. A mild "Z" of about 2" plus a mild crossmember sectioning of 1.5 can give you 3.5" extra clearance, and that's a TON. Just say you lowered your truck 5" in the front, and afterwards, you only have 2.5" of control arm clearance to the ground. Add 3.5" to that..........Hitting the LCAs on everything becomes a thing of the past, and you have a vehicle that rides like a stocker.
Check out my latest endeavor: https://roundsixpod.com My build threads: '55 Chevy: http://67-72chevytrucks.com/vboard/s...d.php?t=247512 '64 C-20: http://67-72chevytrucks.com/vboard/s...d.php?t=446527 |
09-10-2012, 12:14 PM | #31 | |
09-10-2012, 01:36 PM | #32 | |
09-10-2012, 06:52 PM | #33 |
09-10-2012, 11:06 PM | #34 | |
Hollister, CA.
We are all 'old' guys to some people ... I'm getting up there too ! I have alot of cool fab tools at my shop...but my "how-to" was done at home with basic stuff. I just want to show how a person can do it at home, without a plasma even.
09-10-2012, 11:10 PM | #35 | |
Hollister, CA.
I like the idea of just doing the crossmember. In my case, with my '62 burban, I plan on performing a 63 and up frame swap in the future. The crossmember will be already be done.
09-11-2012, 07:53 AM | #36 | |
09-13-2012, 12:11 AM | #37 |
Thanks for the info guys. I am going a static drop and want to get down as low as I can and looking at all the options out there.
Betty : '63 Fleetside Longbed 350 w/ 4 speed CPP 3/5 drop with front sway bar. |
09-13-2012, 05:06 AM | #38 |
here is what you get for clearance with an 8 inch drop in the front
but it looks b!tchin'. i only have a 4in drop in the rear right now.
the Stealth Weapons 63 project, all comments, advice, and critiques welcome! http://67-72chevytrucks.com/vboard/s...d.php?t=438235 |
09-13-2012, 07:58 AM | #39 |
That's not bad! You didn't have to pancake xmember for an 8 inch drop.
09-13-2012, 08:06 AM | #40 |
true but i am very limited to where i can ride around plus speed bumps and flat tires are my worst enemy. also i cant use the drive over pits for oil changes because the LCAs will hit the safety rails
09-13-2012, 08:15 AM | #41 |
09-14-2012, 12:19 AM | #42 |
yes another 1.5 would be great. as of now with either of my front tires completely out of air the LCAs are about 2 sheets of paper from the smooth and level garage floor. imagine having a flat out on a road. i try to prepare for worst case scenarios, for every day cruising 1.5 may not seem like much but it is.
09-14-2012, 07:35 AM | #43 |
Here's a shot we took of mine with all air out of front bags and RF tie flat to check clearance. I had about 2 3/4" under the LCA and a little over 4" at center of crossmember.
AND I can get my speedway aluminum racing jack under the rocker on the frame! |
09-14-2012, 01:42 PM | #44 | |
09-14-2012, 02:30 PM | #45 |
Keepin it old school
09-14-2012, 03:24 PM | #46 |
09-14-2012, 04:35 PM | #47 |
or....
09-14-2012, 05:57 PM | #48 |
