Old 09-14-2012, 10:19 AM   #1
biohazardbill
Bags front, 73-87 Control Arm question
Do you guys keep the bump stops? Or should the be removed? About to take mine to the powder coater and needed to know if I should grind off the bracket first?
biohazardbill is offline   Reply With Quote
Old 09-14-2012, 04:06 PM   #2
lil_sahara450r
Re: Bags front, 73-87 Control Arm question
Most of them I have seen on here have the bump stop and steering stop bracket taken off, but i think it mainly has to do with giving your bag enough room so it doesnt rub on them.
Maybe someone on here that knows for sure will chime in....
lil_sahara450r is offline   Reply With Quote
Old 09-14-2012, 05:27 PM   #3
biohazardbill
Found this pic, not sure of the year of the control arms but they were replaced with a different type of stop. Not sure what this stop is from.. posted in the suspension thread to find out.
Old 09-14-2012, 08:09 PM   #4
lucifer
lucifer's Avatar
Bill Those are universal stops in the picture. I have used them many times after cutting the original stops lower or even off. It all depends on how low you want to go.
65 burb On the road Mar 26th Finally
lucifer is offline   Reply With Quote
Old 09-14-2012, 08:21 PM   #5
MOTOIMPAIRED
MOTOIMPAIRED's Avatar
I ground mine off but I also cupped my lower arms. I would cut them off now incase you want to go lower in the future you wont have to grind your nice powdercoated arms. Like in the picture, You can always use a universal one if needed.
MOTOIMPAIRED is offline   Reply With Quote
Old 09-14-2012, 09:20 PM   #6
scum1
scum1's Avatar
x2 i cut mine and used a universal..its clean and functional
scum1 is offline   Reply With Quote
