Old 09-15-2012, 08:52 AM   #1
Were 16.5 rims factory on 70 3/4 ton burbs ?
Also wondering if anyone knows what other make (ford or dodge product) will fit the lug pattern in a 16
Old 09-15-2012, 11:46 AM   #2
vectorit
What?
vectorit's Avatar
Re: Were 16.5 rims factory on 70 3/4 ton burbs ?
16.5 was on the 1970 model.
There are other wheels that will fit the stud pattern, but the thing to be aware about is the stud size in 1970 is different than what is used today.
Chris
1968 K20 Suburban
1972 K10 LWB PU
vectorit is offline   Reply With Quote
Old 09-15-2012, 12:43 PM   #3
Thanks for the heads up
Old 09-16-2012, 11:11 AM   #4
Vectorit, did you just stick with 16.5's ? Or did you make the switch to 16's ?
Old 09-16-2012, 12:31 PM   #5
vectorit
What?
vectorit's Avatar
I am currently running 16.5's but I do have a set of 16's waiting to go on.
The tires on my 16.5's are BFG A/T's with lots of meat on them, but the problem with that is that they are not perfect. Over the years they have become bent in one direction or the other, so I can't balance them with out putting a bunch of wheel weights on.
But, being that the burb is long and heavy, I never notice this issue with the wheels.
I plan to eventually change to a more narrow tire on the 16's, and by that time I should be planning to take some road trips. To which I will feel better about doing with a wheel that can be fitted with most any brand tire while stuck someplace other than home.
Chris
1968 K20 Suburban
1972 K10 LWB PU
Old 09-16-2012, 01:25 PM   #6
1985-GMC
Chevy Enthusiast
1985-GMC's Avatar
Where are you at it Tx 57Napco?
I'm still running 16.5's and I'm about to switch over to 16.5 dually wheels on my 78. I'm gonna go with 37" hummer tires on everything.
Tony
1985 GMC K2500 restoration Project: Rust, White & Blue
1989 Chevy R3500 CC Cummins & 4X4 swap some day...
1989 Burb (D60, 14BFF, 12V, NV4500, NP205, 37" tires in progress)
1985-GMC is offline   Reply With Quote
Old 09-16-2012, 01:51 PM   #7
About an hour north of you, MFalls area.
Old 09-16-2012, 02:37 PM   #8
The 8-lug pattern was standardized between all truck brands (6.5" pattern) until good ole Ford decided to mess things up by going to 170mm in '96 or so. A few years ago GM followed suite and I'm pretty sure Dodge did,too. One day an engineering whiz wakes up and decides to change what's been a standard for decades (like ever since the 8-lug pattern came out!) just for the sake of change,with no benefit or improvement resulting what so ever.
