![]() Join Date: Jan 2012
Rearend question
Ok so pulled the rearend out of my parts truck. It's a 12 bolt posi the old man I got it from thought it was a 373 but it did not say that on the spid. So it being a 350 auto truck c10 I figured 3.07 so before I took it out I did the ol mark the tire and turn it and count how many turns it takes to make one rotation. It was 3 1/4 with would be 3.55 so does this sound correct? I guess I just need to crack it open and take a look.
Posted via Mobile Device |
Re: Rearend question
Showing 3.07 as the standard ratio for that powertrain with 3.73 or 4.11 as optional. Probably a 3.07. If it is loose pulling the cover, inspecting and cleaning is always a good idea.
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
That's what I figured it was but I will get it cleaned up and tear it all down and take a look got a set of 3.73s for it since I'll be running a 4L80E hate for it to be a dog in overdrive. And thank ya sir for the reply always enjoy your post.
#4 | |
![]() Join Date: Mar 2011
3.73 and numerically higher use a 4 series posi unit. You might want to look into that before unpacking your new gears. ![]()
My build thread - Devastation and Reform http://67-72chevytrucks.com/vboard/s...d.php?t=567131 |
