Old 09-17-2012, 03:34 PM   #1
looney
Need help ordering parts
I am needing to order the floor pans, rockers, cab supports, and cab corners. I am not sure what I need. Looking in LMC online catalog, do I need half cab floor plus outer cab floor. Do I need inner cab support and inner rocker and outer rocker. Part of floor and everything dealing with rocker panel needs replaced just want ot order what I need and not what I don't. The online catalog is on page 25. Any help is appriciated.
looney is offline   Reply With Quote
Old 09-17-2012, 03:47 PM   #2
JimKshortstep4x4
Re: Need help ordering parts
Without seeing the rusted areas of your cab it is a little hard to know what you need. It seems though that your only real issue is the floor. If the outer floor PN 7 eleminates the rust on the floor then that is what you need since it has the inner rocker as part of the piece.
Rockers, cab corners, and cab supports are all separate pieces. If you post a picture you may be able to get more detailed help.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 09-17-2012, 03:48 PM   #3
GMCJOE
GMCJOE's Avatar
Best bet is to call and ask. Tell them what you want/need. They know what they are doing and are very helpful. I live not far from there, and buy parts from them from time to time.
GMCJOE is offline   Reply With Quote
Old 09-17-2012, 03:58 PM   #4
looney
Tried calling but they said they have no mechanics working there they can only give me parts I need.
Old 09-17-2012, 04:01 PM   #5
looney
Here is what I'm looking at.
Old 09-17-2012, 05:08 PM   #6
dmw319
from that picture it looks like you will definately need inner and outer rockers.
can you post a picture of the corners or the cab from the underside of the truck? most likely you will need them too
1970 Chevy C-10 Stepside
My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=528167
dmw319 is offline   Reply With Quote
Old 09-17-2012, 09:29 PM   #7
cerjio
Speaking from experience to replace all of that ! if both doors need it an you have the skills by the new floor pan , then replace the outer rockers , I pieced all of mine an then they came out with the new pan , I would have replaced the whole floor if I they had them back then
cerjio is offline   Reply With Quote
Old 09-17-2012, 10:52 PM   #8
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Look for the vendors on this site. They talk trucks. Here's one in your geographic area, too. http://sokyclassics.com/
Member Nr. 2770
Old 09-18-2012, 06:33 AM   #9
bobs409
1969 Custom 30 wrecker
bobs409's Avatar
I would replace the whole floor pan if possible. Only downside is you have to completely tear the truck apart!
I've done the peice by piece fix method and it down right sucks! I avoid that like the plague now.
Bob
63 Impala 283/PG/3.36 (under restoration)
66 Impala 327/PG/3.36
66 Chevelle SS 409/M22/3.55
69 Chevelle 307/PG/3.08 (future restoration)
69 C10 short stepside 454/TH350/3.73
69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!)
71 Cheyenne 20 fleetside 350/4 spd/4.10
71 Chevelle 6/PG/3.08
72 Chevelle 454/M21/4.10
bobs409 is offline   Reply With Quote
