09-15-2012, 09:18 AM | #26 |
Re: rear end swaps
He wants to know the wheel mount surface(WMS) to wheel mount surface measurement.
John 82 Chevy Silverado 350ci/TH350 |
09-15-2012, 10:00 AM | #27 |
Re: rear end swaps
never seen that abreviated before.
09-16-2012, 03:25 AM | #28 |
Re: rear end swaps
Wheel Mating Surface.........looking for WMS to WMS measurement
1967 K30 4x4/12v Cummins/getrag/D60/D70/355s 1967 GMC suburban 4x4/LS swap 5.3/4500/205/10 bolt/14 bolt full floater 1963 C10 reg cab long box 1970 Chevelle 1968 Biscayne 2dr post "...there is no excuse for what I am about to do, but dangit....it's gonna be fun!" |
09-16-2012, 07:16 AM | #29 |
78K & 79C Jimmys
Re: rear end swaps
my 79 4X2 has a 12 bolt locker it's RPO 1G80 if you see that one
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 Last edited by motornut; 09-16-2012 at 07:49 AM. |
09-16-2012, 11:17 AM | #30 |
Re: rear end swaps
Officially called the ALD (automatic locking differential) according to GM.
It's come to be known as the "gov bomb" among the general population though |
09-16-2012, 01:42 PM | #31 | |
Re: rear end swaps
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac 3''spintech prostreet mufflers xpipe 1 3/4 headers build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217 Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511 |
09-16-2012, 04:11 PM | #32 | |
Re: rear end swaps
Parking brake is an easy hook up. |
09-16-2012, 04:29 PM | #33 |
72 BB C30 Super LongHorn
Re: rear end swaps
My 10-Bolt swap from a 1985 1/2 ton into a 1975 SWB Fleet C/10 :
10 Bolt 8.5 Truck rear axle. 2:56.1 8.5 ring & pinion. 2-series Eaton Posi. Moser Axles : Brand New. New drums, shoes, wheel cylinders, spring kits, bearings, seals, crush sleeve, 1350 U-Joint Heavy Duty Pinion Flange. Some of the small bolts were metric, others not; just fyi. Do note that we had to change the parking brake cables from the prior 12-Bolt into the 10-Bolt backing plates. The 1985 parking brake cables were longer than the stock ones from the 12-Bolt that were correct length for a SWB.
72 BB C/30 Longhorn Super HO72 No-Spin, #'s matching, Tilt, Tach, AC, AM/FM HO72 build : http://67-72chevytrucks.com/vboard/s...d.php?t=714492 2017 SS |
09-16-2012, 11:15 PM | #34 | |
Re: rear end swaps
A Ford differential that is 5x5?????? really?
09-17-2012, 06:48 AM | #35 |
Re: rear end swaps
Sure, all your big ford cars as well as linclon and mercury from the 70s & 80s are 5X5 bolt pattern. (some mid 70s F100 &F150 pickups are 5X5 also) and the
center hole is the same as GM. I use factory 15X8 GM truck rally wheels on my ford (Linclon) 9 inch. This one was in my 73 C10 SWB for over 10 years and 60,000 miles 3.70 gear, 28 spline with a trac-loc diff. [IMG][/IMG] Last edited by wraprail; 09-17-2012 at 06:55 AM. |
09-17-2012, 07:14 PM | #36 |
Re: rear end swaps
Wraprail, Any perticular vehicle to look for for a posi, and are the widths the same for 85 chevy thanx
09-17-2012, 08:18 PM | #37 |
Re: rear end swaps
I would assume that an 85 C10 would be the same width as a 73 but I don't know for sure. As for the posi/locker, i just check pick-a-part in the truck section. In the case of a 9 inch, I usually look at Bronco and F150 4x4s. Often they have an ID tag that shows the gear ratio. If both tires spin together in the same direction that usually indacates a posi or locker. You have to pull it to be sure and to check if you have a 28 or 31 spline.
Posted via Mobile Device |
09-18-2012, 10:07 AM | #38 |
BAD BOW-Silverado XST
Re: rear end swaps
Sweet 9"!! Nice upgrade!
