disc brake swap question
I just bought disc brakes off of a `71 1/2 ton and they gave me the a-arms too. are the ball joints the same for my 68 and the 71 or do I have to change them?
Keepin an eye out
Not the same. You need to use '71-'72 ball joints.
1970 Chevy C10 SWB 5.3 1996 Toyota Tacoma SR5 4x4 2007 Vespa GTS 250 Scooter ZIP 91351 |
Fabricate till you "puke"
Yup, you will need tierod assys also......& possibly the centerlink. Good luck,crazyL`
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
thanks guys. i was afraid of that
Anthony |
good luck!
70 longbed 496/th400/Ford 9" |
will the 71` a-arms fit my truck? i was given those too.
Yes,
Just be careful removing the springs on your truck.
69 swb stepside, rebuild and upgrade in progress |
thanks matt, i always chain the springs so they don`t shoot out. also, how do i know if the upper and lower shafts are worn out?
yes, the 71 a arms will bolt right on. The bottoms are different than your 68's , in the steer stop location, The top arms do not need to be changed(just bolt the later ball joints in). as far as bushings/shafts, if you feel any looseness at all , replace them. The good thing about the bushings on the 67-72s , is that if you keep them greased.......they are good for about a 1/4 million miles! most of the orig owners did not grease them tho..... crazyL
