09-07-2012, 01:31 PM | #1 |
weld on 4.5" lift, front end
just wondering if anyone has used this on a 2wd to 4wd convertion
http://www.polyperformance.com/shop/...p-p-19164.html lets see some pics if you got them
88 gmc v3500 bonus cab classy chassy conversion, 454, nv4500, np205, dana 60 front with spool, 14 bolt ff cac rear with locker. |
09-11-2012, 07:24 PM | #2 |
Grease Monkey
Re: weld on 4.5" lift, front end
I can't offer you any pics since I've never used the kit. I have heard good things about Poly Performance and there kits. I have bought stuff from them and has been good quality. Good Luck
Tow Rig: 2012 Chevy 2500HD CCSB LTZ Z71 4x4 Duramax Ultimate Offroad Build: 1978 Chevy Silverado K30 Crewcab Build Link http://67-72chevytrucks.com/vboard/s...d.php?t=654053 Mud Truck: 1972 Chevy Cheyenne K30 4x4, 468/400/205, D60/D70HD, 18" Custom Lift, 17x39" IROKs FOR SALE http://67-72chevytrucks.com/vboard/c...ton-4x4&cat=12 |
09-11-2012, 08:28 PM | #3 |
Sky man. is cheaper...
2000 GMC CCSB 454/4L80 6” lift SAS 1999 Chevy CCSB 454/NV4500 4” SAS 1999 GMC Yukon 350/4L60 6" SAS |
09-11-2012, 10:28 PM | #4 |
stock 4x4 front parts are way cheaper. practically the same amount of work. and that big front crossmember looks ridiculous IMO.
09-18-2012, 02:04 AM | #5 |
Collector of Projects
check www.diy4x.com too
09-18-2012, 03:59 AM | #6 |
i got lot of problems that add up to why i even considered this kit
1 my 87 is 2wd and my daily driver 2 the parts truck im using is 4wd and its a 1980 ... front hangers are diffrent 3 cross over steering need atleast a 4" lift my plain is to do this over a fue weekends starting out with welding the hangers on and swoping the rear axle so i can take then to get the ratios chainged to match then i'll put the nv4500 and np205 togeather and slide it in the truck and put the other crossmember in after that get the speedo calibrated and its a done deal
09-18-2012, 08:27 AM | #7 |
Resident of Here
DIY4X B52 kit. 52" or 56" front springs. 6" shackle. Offroad Design FUSH Kit.
~Bradley~ 2004 Black GTO LS2/T56 too much to list Miss having a truck |
09-18-2012, 03:26 PM | #8 |
All 73-87/91 front spring hangers and shackle hangers are the same.
Posted via Mobile Device |
