Old 04-21-2010, 01:41 PM   #1
PBFAB.COM
PBFAB.COM's Avatar
60-66 Hood Hinges
60-66 Cowl Mounted Hood Hinges $265
By Porterbuilt Street Rods
It was only a matter of time before we dialed in our cowl mounted hood hinges for the 60-66 C10s. We have been offering a re-locator bracket for the factory hinges for a few years now, but they limited the overall tire diameter to 27”… that kept the wheel selection to a 20” rim. These new cowl mounted hinges will allow the frame-rails to touch-down without tire to hinge clearance issues. The Install is simple and straight forward, and requires some cutting of the cowl panel, welding a mounting pad to the rear hood hinge support, and of course… careful measuring!
Here’s a quick installation write up on the hinges… look for a better write-up in the near future!
The hinges need to be mounted 45.625” apart (that’s 45 5/8). Find the center-line of the cowl and make a reference mark. There will be mounting hole real close to center where the cowl panel screw mounts. Once the center-line of the cowl has been found, measure out towards the fenders 22.8125” (that’s 22 13/16”) and make a reference mark. This will be the center-line location for the hood hinge pockets.
It will be necessary to cut a hole in the cowl so the hinge pocket can be installed. Make sure you leave a small lip on the front of the cowl for strength, and also be careful as the cuts will get close to the wiper mechanism.
Make a template of the hinge pocket mounting holes with posterboard or paper and transfer the pattern to the cowl.
Drill the holes and cut the slit for the hinge arm. I find it easiest to drill two holes at the top and bottom of the slit and then connect them with a cut-off wheel.
Install the hinge pocket and hinge arms (there is a RIGHT and a LEFT side. The bottom of the hinge pockets are angled to follow the slope of the cowl). The pocket will be installed first, and then slide the hinge arm through the slit. Check for clearances and make adjustments where necessary. Install all mounting hardware.
Just like our 67-72 hinges, there is a mounting pad that needs to be welded to the hood brace on the underside of the hood. The heat from the weld WILL NOT affect the exterior paint. Just as with the cowl panel, you will need to find the hood brace’s centerline. There are a couple of holes in the brace that will be near dead-center. Make some measurements to verify this.
The hood mounting pads’ centerline needs to be the same as the hinge pockets’…45.625” (45 5/8) once centerline is found, make a mark. Measure out 22.8125” (that’s 22 13/16”) and make a reference mark on each side. This reference mark will be the centerline for the hood mounting pads. The back of the mounting pad will measure 1” off the rear edge of the hood brace (see picture below). Verify this measurement to be as close as possible. Careful measuring during this portion of the install will make things much easier! Set the mounting pad in place on the hood, verify measurements, and clean the surface before welding. Tack the pad in place and test fit the hood.
Once the mounting location of the hood pads has been verified and test fit, remove the hood and fully weld the pads to the under-hood brace. Install the cowl panel before the hood goes on for the final time. There is ample fore-aft adjustment for the hood to set the gap at the cowl, and there are also shims available (if needed) to adjust the height of the hood at the cowl.
www.PorterbuiltFabrication.com
Phone: 480-297-2621
E-mail: sales@pbfab.com
Find us on FaceBook under Porterbuilt Fabrication
Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck.
We offer components from the following manufacturers:
Porterbuilt
Accuair
Ridetech (Air Ride Technologies)
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Supporting this forum since 2003!
PBFAB.COM is offline   Reply With Quote
Old 04-21-2010, 02:45 PM   #2
derider
derider's Avatar
Re: 60-66 Hood Hinges
Yes! Awesome Nate. I am currently saving for my dropmember and these are a very necessary addition, what are the brackets on the fire wall?
68 Chevelle 396 4spd-sold needed money when I got married
Current build-66 C-10, 350, 4spd, disc brakes, CPP 3-5 drop, saving for Porterbuilt drop member
derider is offline   Reply With Quote
Old 04-21-2010, 03:04 PM   #3
PBFAB.COM
PBFAB.COM's Avatar
Those are the old re-locator brackets for the original hood hinges.
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 04-21-2010, 05:24 PM   #4
Bazooka
Keepin it old school
Bazooka's Avatar
Like I said in the other thread I am so stoked that these are done..
I will def be placing my order in the next couple weeks.
Bazooka is offline   Reply With Quote
Old 04-21-2010, 05:27 PM   #5
ruffrida2005
Member of the longbed union.
ruffrida2005's Avatar
I would place an order but I'm broke. Send me the cad file and I'll make them. haha
Paul
88 GMC Crew Cab dually, 454/T400
64 LWB 400 HP 350/350T Bagged, under construction! Sold most of it!
92 S10 Iron Duke 5 speed, 5/7 drop for now. soon to be bagged. Sold http://67-72chevytrucks.com/vboard/s...59#post4637759
ruffrida2005 is offline   Reply With Quote
Old 04-26-2010, 01:47 PM   #6
98L150
///Relaxed Atmosphere
98L150's Avatar
i know who i will be calling in the next day or so
72 Suburban
64 Chevy short fleet
04 Chevy Colorado Sport Reg Cab
2012 Chevy Avalanche
2003 Chevy S10 Blazer Xtreme
http://www.hubgarage.com/mygarage/RA_Jeff
64 Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=295915
98L150 is offline   Reply With Quote
Old 04-28-2010, 08:08 AM   #7
lakeroadster
Porterbuilt,
The stock hinge mechanism lifts the hood upward more than in an arc. Does the stock front hood latch work with this arrangment?
lakeroadster is offline   Reply With Quote
Old 04-28-2010, 12:48 PM   #8
PBFAB.COM
PBFAB.COM's Avatar
Originally Posted by lakeroadster View Post
Porterbuilt,
You are correct, the hood swing will be at a different arc than the factory hinged hood.... fortunately, the factory latch and safety catch still works just fine.
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 07-29-2011, 07:31 PM   #9
isdeleon
isdeleon's Avatar
how will the hood be kept open? just that you still don't offer the gas shocks for the 60-66... or am i missing something... jaja, plan on buying it soon, hopefully...
My truck spends more than my wife, is that normal?
isdeleon is offline   Reply With Quote
Old 07-30-2011, 07:37 AM   #10
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
nice setup
Old 07-30-2011, 09:16 AM   #11
Notch1988
Notch1988's Avatar
Originally Posted by isdeleon View Post
how will the hood be kept open? Just that you still don't offer the gas shocks for the 60-66... Or am i missing something... Jaja, plan on buying it soon, hopefully...
x2
Notch1988 is offline   Reply With Quote
Old 07-30-2011, 11:18 AM   #12
PBFAB.COM
PBFAB.COM's Avatar
The hood stays open with a prop rod, or man power with this set-up. We will be coming out with a gas assist upgrade that is compatible with these hinges. It will not be the same style as our 67-72 version, as these hoods are just too heavy to be supported that way.
Nate
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 07-30-2011, 11:32 AM   #13
creep
Registered Loser
creep's Avatar
Can't wait for the upgrade. I feel like I need a nap every time I open my hood
'63 GMC lwb, 383, th350, lays frame, genuine patina.
The Build Thread - http://67-72chevytrucks.com/vboard/s...d.php?t=374267
'88 Astro cargo bagged, shaved, phantom grille. *SOLD*
'50 Chevy 2 door sedan awaiting attention.
2014 Silverado Ext cab, 5.3, daily driver.
creep is offline   Reply With Quote
Old 06-04-2012, 01:24 PM   #14
zippeay
zippeay's Avatar
Is it possible to keep the stock A/C box with these hinges? I'm assuming not because it looks like the left side goes in the same place as the A/C box.
zippeay is offline   Reply With Quote
Old 07-08-2012, 12:41 PM   #15
idreama300
Any idea when the strut assist hinges will be available?
idreama300 is offline   Reply With Quote
Old 09-20-2012, 02:56 AM   #16
westcoast5
no kidding!
Bryan
1966 SWB BBW "SICKT6"
Accuair|Porterbuilt|Bodied|Shaved|Z'd|350 with minor goodies|5 lug|front disc|3.73 rear|CPP power steering/brakes|few more goodies| thanks to C10Clubapparel
westcoast5 is offline   Reply With Quote
