White Walls Lets see them
I'm about to buy some i'd like to compare what everyone has so if you get them lets see them! I'll post some to start
![]() Last edited by 68steppsidee; 05-31-2011 at 09:54 PM. |
Active Member
![]() Join Date: Jul 2007
Re: White Walls Lets see them
Personally, I prefer the narrower whitewalls.
![]() shaved down some bf goodrich longtrail raised whites ![]()
70 c10 long bed 57 chevy 2 door wagon 07 tahoe 96 civic commuter |
454 MAKES IT ROAR
Couple i've saved.
Nigel. An American living in a British body. 1971 Chevy Cheyenne 10 454 "In a time of universal deceit, telling the truth becomes a revolutionary act." - George Orwell "When injustice becomes law, resistance becomes duty" - Thomas Jefferson No more pain. 03.12.60 -- 12.28.10 http://www.youtube.com/Eightbanger |
pretty nice any stepside with white walls
What you're looking for is "wide white walls". That's what they are referred to as and whitewalls are the narrow ones that were installed on these trucks through the years. Wide whitewalls are a current trend never seen on these trucks before. Some look pretty cool. Although,it's hard for me to look past them being from an era long gone before these trucks hit the road.
![]() Join Date: Sep 2010
Try this link then: http://67-72chevytrucks.com/vboard/s...d.php?t=416428 There's a lot of those kind on this one. . . . . Last edited by Steve Hafner; 08-19-2012 at 07:00 AM. |
thanks!!
#9 | |
#10 | |
What?
To me, something about the look just seems "wrong" about it.
Chris 1968 K20 Suburban 1972 K10 LWB PU |
white walls
These came out nice!! I used to live out in the High Desert not long ago. I have a few questions for ya if ya don't mind:
Did you do these or have a local shop? If so, where? I have a Bro in Hesperia looking to do this. How wide of a white wall did you end up with? Did all 4 turn out the same? Also what size tires are you running? I need to swap my WWW out soon and was thinking to use the same brand and model tires. Thanks SSchevimp A couple of links for making wide white walls. NOTE: I did buy a single raised white letter tire from Les Shwab and did this. It did not work as hoped. I know that the BFG T/A's used to get this treatment back in the day and looked good. Hoping the BFG Long Trail Tour will do just fine. Thanks
..............................._________ ......___________//___[[___{\ _____ ...../__(_(O)_)___/____/____/_(O)_/ 1964 C20 Long Stepside 3 Door Crew Cab - Armbruster-Stageway Conversion Y2K INDN Chief "ONE OF A KIND, NOT ONE OF THE CROWD" Aug 2010 - Front end frame cleanup & engine swap done!!! June 2011 - Rear end bagged Sept 2011 - Rebuild motor top end Sept 2012 - Parked and slowly working on it. Aug 2013 - Front end bagged - finally! Aug 2014 - Stepside swap conversion done. Finally ready to start bodywork! Have a few KEWL ideas... Here is my build thread: http://www.67-72chevytrucks.com/vboa...d.php?t=335427 |
I did them myself with them off the truck and I used a grinder with a sand paper disk. They all came out the same and they clean up real well with bleech white
I'll get the size for ya Posted via Mobile Device
Great & Thanks!! also how wide of a white wall did you end up with? Jus as far at the lettering or more? Is it possible to get a close up of one of the tires? Thanks again!!!
#15 |
I also like the thin white walls
#16 |
Just wonderin if ya were able to get the tire size? Thanks!
#17 |
Sorry man not yet, the truck is parked on the dirt and there's a ****load of those goat head weeds around it... I'll try and get it tomorrow, I have to look at the back side of the tire
#18 |
This guy used to work for Tyre Tred in Hayward, CA an long time shop thats been closed for a few years now.
I calling him tomorrow to see if he can do my 16's. The following is from Lay It Low forum From 04-02-2012, 10:21 PM WIDE WHITE TIRE BUFFING BACK IN HAYWARD $12.50 each tire, off rim Hello my name is butch I have been in the tire business for the last 30 years, and I have been buffing white walls for about 25 years now. I use a tire buffing machine from the 50s.This is the best way to buff a white wall tire out.The best way to get a hold of me is my cell 510 688 6525 butch .Thanks http://www.youtube.com/watch?v=MuAJ-...ature=youtu.be
#19 | |
Gonna go with same brand and possibly the 235/75-16.
#20 |
235/70/16
I got 2 in white wall out of it, If you can't get that guy to to it I remember a spot in Modesto that shaves whitewalls called Paradise tire and there is a shop in Stockton too... Not sure of the name Posted via Mobile Device
#21 |
Great Thanks! The place link I posted above is for a guy that's been doin our tires in the Bay Area for years. The shop dates back to the early 60's but closed a few years ago after the owner died. BUT this guy was able to keep buffing machine and is offering the service as of this past April. Only concern since this is a 1950's machine - it may not be able to do the 16" tire.
Calderons Tire on Alum Rock in San Jose, CA can do almost any size tire mounted on a wheel and on their spindle using the same buffing machine. Thanks again for your info!!
#22 |
![]() Join Date: May 2012
these are mine...
#23 |
Your truck turned out real nice ole dollor.
I'm not as good as I once was, But I'm as good once as I ever was. |
#24 |
well thank you very much big mike 71, i am really proud of it.....
#25 |
Here's a pic of mine I found on the internet that someone took at the Pigeon Forge, TN Grand Fall Rod Run.
1980 Malibu Classic 2 dr coupe 1964 Impala SS 4 speed 1968 GMC (major project) grandpa bought new 1969 Chevrolet C-10 Shortbed Fleetside 2008 GMC Canyon (daily driver) |
