09-15-2012, 01:15 AM | #1 |
what is this from?
hey guys im thinking about putting this intake on my 350 when i rebuild it. its a gm part. aluminum dual plane. any idea as what it is from and if it will increase performace over my stock cast iron manifold?
09-15-2012, 01:22 AM | #2 |
Re: what is this from?
is there a part # on it?
SOLD -77 CHEYENNE SWB, LS SWAPPED -1976 SILVERADO YUBA GOLD/NEUTRAL (2-TONE) |
09-15-2012, 01:22 AM | #3 |
It's just an aluminum version of the cast iron one. No difference performance wise.
IIRC they came on some 305's. |
09-19-2012, 11:36 AM | #4 |
I have a mid seventies 350 with 882 heads and the stock cast iron intake and q jet carb. Will this manifold bolt up with no modifications in place of the cast iron?
Posted via Mobile Device |
09-19-2012, 11:44 AM | #5 |
the only difference I know it is a bit lighter
09-19-2012, 12:27 PM | #6 |
Ok my cast iron manifold is pretty best up and guy I bought the truck from gave me this one so im hoping it fits without a problem.
09-19-2012, 12:55 PM | #7 |
It's lighter and will disapate heat better. I'd put it on if I had it.
If you can't impress them with your inteligence, dazzle'm with your stupidity 1969 GMC lwb 2wheel drive can you say big stroker motor to come hehe |
09-20-2012, 12:13 AM | #8 |
09-20-2012, 12:35 AM | #9 |
Ok thanks guys I will be swapping the manifold in about a week once I get the heads and block cleaned up. They both have a lot of blocked openings on the water passages which basically blew my head gaskets and put water in the oil.
09-20-2012, 11:18 PM | #10 |
I replaced the cast iron version on my 454 with a performer. Went from sluggish to a neck snapping tire roaster. Runs SO much better in general.
I suggest getting rid of it...particularly if you are running a square bore, like a Holley. That one is designed for a spread bore (Q-jet). The only disadvantage with the modern manny is it doesn't look original. |
