Disc Brake Conversion
We not only do big brake kits, but we can also get the parts you need to do a disc brake conversion with a 12" rotor. We have put together our Pro1 disc conversion kits to give you all the quality parts needed in order to swap your front drum brakes to disc.
They include a 2.5" drop spindle, but a stock height spindle is available for 63-70 C10's. Pro1 Disc Brake Conversion - From $789 ![]() We put together our Pro1 60-70 Disc Brake Conversion kit to simplify the process in figuring out what you need. Now, you can order one part number, and receive everything you need to convert your truck over to disc brakes, the right way. The system uses all McGaughys parts, so you know you are getting good quality! Parts Included: 2.5" Drop Spindles (or Stock Height Spindle) 12" Plain Rotors Calipers Bearings Brake Lines Brake Pads 7" Brake Booster Master Cylinder Non-Adjustable Proportioning Valve Fits: 60-70 GM C10 Trucks with Drum Brakes (1/2 Ton, 2wd) |
