Re: Engine Bracket help (please)
they should be part number 334601 and 334602 , the nut end goes to front
2008 Silverado Z71 RCSB 1991 GMC Jimmy 4x4 1976 GMC Sierra C15 SWB |
Can you tell me what the physical difference (if any) there is between the 334601 and the 334602?
Having slight alignment issue with engine fan setting closer to right side of shroud. I have the 334601 on the right (passenger) side of the engine block and the part number on opposite side is not ledgible, but i am assuming it is the 334602. This engine with mounts and all brackets came out of one owner stock 350ci 77 chevrolet C10. Did i screw up and need to reverse these two mounts left to right to fix my issue? |
