Old 09-17-2012, 12:08 PM   #1
king-918
king-918's Avatar
who's running a KP cantilever? experiences and pictures
Thinking I want to run one
<----Christopher
Oh yeah I'm really a Toyota guy, but had some stuff sitting around.
Oklahoma
king-918 is offline   Reply With Quote
Old 09-17-2012, 01:37 PM   #2
tubbedII
needs more $$$
tubbedII's Avatar
Re: who's running a KP cantilever? experiences and pictures
My brother and I considered running this set up with his C10, but the 2 downfalls to it were the frame tends to bend where the bag mounts (bracing fixes this issue though), and the rear dog bones hang low, especially if running big wheels. Niether of these are real deal breakers, but he's going with the PB set up instead now...mainly due to the fact that you can't see the dog bones.
1970 2wd Blazer
tubbedII is offline   Reply With Quote
Old 09-17-2012, 03:37 PM   #3
PBFAB.COM
PBFAB.COM's Avatar
It's a nice kit and looks pretty cool. The one drawback that I see is that the bags are located pretty far behind the notch putting a lot of leverage on it. It will flex a little as mentioned. If you're going for cool factor it's a neat set-up.
Nate
www.PorterbuiltFabrication.com
Phone: 480-297-2621
E-mail: sales@pbfab.com
Find us on FaceBook under Porterbuilt Fabrication
Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck.
We offer components from the following manufacturers:
Porterbuilt
Accuair
Ridetech (Air Ride Technologies)
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Supporting this forum since 2003!
PBFAB.COM is offline   Reply With Quote
Old 09-17-2012, 05:55 PM   #4
SevenOne
SevenOne's Avatar
is that(flex and dogbone issue)only for the older c10's?Or same issues for 99+ chevys aswell.thnx
SevenOne is offline   Reply With Quote
Old 09-17-2012, 06:29 PM   #5
PBFAB.COM
PBFAB.COM's Avatar
I have never installed one on a 99+.
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 09-17-2012, 06:34 PM   #6
king-918
king-918's Avatar
Flex noted, don't mind parts being exposed. Nice look to me
<----Christopher
Oklahoma
Old 09-19-2012, 09:03 AM   #7
andrewmp6
I would look around see if you can find a nicer weld in kit for it.
Old 09-19-2012, 10:10 AM   #8
king-918
king-918's Avatar
Why?
<----Christopher
Oklahoma
Old 09-19-2012, 10:19 AM   #9
king-918
king-918's Avatar
Nate
I was thinking about the added needed to move the leverage, so I thought I have ss7's for the front but should run a wider bag in the rear for a kp?
<----Christopher
Oklahoma
Old 09-19-2012, 11:24 AM   #10
PBFAB.COM
PBFAB.COM's Avatar
I have only installed a couple, and we used the 7s from Slam. A different bag will not eliminate the flex, as it is inherent in the design. With all the weight being carried behind the notch, it will have flex regardless of which bags you go with.
Please don't misinterpret my comments. The kit works, and is pretty trick looking with all the mechanical parts.
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 09-19-2012, 12:10 PM   #11
king-918
king-918's Avatar
Are you talking about flex in the frame? I thought that's what you meant, but I was talking about since the bag is placer further away from the axle it would take more energy to raise the truck in the rear. So I was thinking of running like a ss8. My thought process was wider bag required less psi to achieve same lift
And I appreciate the conversation. I love to learn, and get an understanding of why/why not
<----Christopher
Oklahoma
Old 09-19-2012, 02:08 PM   #12
PBFAB.COM
PBFAB.COM's Avatar
The flex I am referring to is in the frame, at the notch. With the weight of the rear half of the truck being supported behind the notch, it puts a lot of stress and leverage on the notch making it flex more than it would with different configurations. This can be minimized by extra bracing located in the correct places.
I wouldn't bother going with an 8" bag.
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 09-19-2012, 07:00 PM   #13
king-918
king-918's Avatar
Thanks for the info!
<----Christopher
Oklahoma
Old 09-19-2012, 07:03 PM   #14
king-918
king-918's Avatar
The funny thing is I still have not heard anyone say they are using one?
I also have another question. Prothane Vs. Energy?
<----Christopher
Oklahoma
Old 09-19-2012, 07:04 PM   #15
PBFAB.COM
PBFAB.COM's Avatar
Dino ran one on his white square body... maybe you can PM him for some feedback.
Nate
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 09-19-2012, 11:37 PM   #16
osaltyone
osaltyone's Avatar
I am running one with the Porterbuilt frontend. It seems to ride pretty good, never had a bagged truck b4. If Nate had his when I originally bought mine I would have just ordered it all in one place. Only issue I have had is with the notch for the drive shaft. I had to trim it, raise it up and weld it since it was hitting the drive shaft.
osaltyone is offline   Reply With Quote
Old 09-20-2012, 09:21 PM   #17
king-918
king-918's Avatar
What took you soo long. Very nice truck. Thanks for the insight and nice truck
<----Christopher
Oklahoma
Old 09-20-2012, 09:22 PM   #18
king-918
king-918's Avatar
Soo energy vs. Prhothane
<----Christopher
Oklahoma
Old 09-21-2012, 01:42 AM   #19
osaltyone
osaltyone's Avatar
Been building and learning as I go for the past few years. Doing it on my own. I am running Poly, just had to make sure they are greased.
Old 09-22-2012, 02:56 PM   #20
king-918
king-918's Avatar
Thanks again. just order my set from pro performance
<----Christopher
Oklahoma
