Closed Thread
Old 09-22-2012, 04:34 PM   #4901
jayman68
Fun Stuff
jayman68's Avatar
Re: What did you do to your truck today!
Originally Posted by Trsmotrhed View Post
Finished my motor mounts for my LT1 swap into a 63 c10. Raised the motor 5/8" to help clear the AC instead of spending money on brackets. Worked great with all the room under the hood.
Now to fit the headers and fuel lines. Waiting for my stand alone harness and ECM I got a killer deal on with VATS and smog deletes already done. I want to build a thread, but new to this site and have no idea where to start.
Welcome to the forum.
To do a build thread, click on "forums" on the tool bar, then under "The 1960 - 1966 Chevrolet & GMC Pickups Message Board" there is a sub forum "Projects and builds". Click on that and then click on new thread, upper left.
Or just click here,
http://67-72chevytrucks.com/vboard/f...play.php?f=197
Good luck with the project.
Jay
68 C10(project)
88 Honda Accord(DD)
93 Chevy Astro EXT 2wd
jayman68 is offline
Old 09-22-2012, 05:07 PM   #4902
shawno72
C/10 junkie
shawno72's Avatar
Just came in from installing my c-notch
Shawn
70 LWB C10 current driver/project
http://67-72chevytrucks.com/vboard/s...d.php?t=663051
68 SWB C10 Work in progress.....SOLD
http://67-72chevytrucks.com/vboard/s...d.php?t=559520
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
http://youtu.be/kbB0QrBIs9k
My mom always had the best advice. It was just a tad late. After a fall that involved blood, she'd say....."Careful!"
shawno72 is offline
Old 09-22-2012, 05:39 PM   #4903
Trsmotrhed
Trsmotrhed's Avatar
Or just click here,
Thanks Jayman68. I started a thread I think.
Trsmotrhed is offline
Old 09-22-2012, 05:47 PM   #4904
jd7
jd7's Avatar
I am happy to say I installed a lokar kickdpwn switch on my truck so my new 400 trans will kickdown with the greatest of ease and look good doing it
jd7 is offline
Old 09-22-2012, 05:47 PM   #4905
smallwin67
smallwin67's Avatar
Sanded down the bed today..Got tired of looking at the faded black drab paint that PO had on her..Not done yet,still got along way to go..Kinda dig the original sea foam green.
Doin it one piece at a time.
smallwin67 is offline
Old 09-22-2012, 05:47 PM   #4906
71tahoe
71tahoe's Avatar
Got back after dark yesterday (so didn't post) from picking up an 94 five lug 3:42 posi (we'll see...) for my '71. Spent most of the day rearranging my shop to have a little more room to work.
71tahoe is offline
Old 09-22-2012, 06:45 PM   #4907
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Weld grind repeat today just in for a break and figured Id check in on this thread...
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline
Old 09-23-2012, 11:43 AM   #4908
UNEASYRIDER
UNEASYRIDER's Avatar
Covered the shifter hole and added cup holders
DON'T BUILD IT IF YOUR NOT GONA DRIVE IT!!
UNEASYRIDER is offline
Old 09-23-2012, 11:48 AM   #4909
VDOG
Grand PooBaa Member
VDOG's Avatar
Thats a cool mod.
VDOG is offline
Old 09-23-2012, 04:07 PM   #4910
hayhauler71
hayhauler71's Avatar
Fuzzy likes it
Fuzzy
hayhauler71 is offline
Old 09-23-2012, 04:15 PM   #4911
shawno72
C/10 junkie
shawno72's Avatar
Originally Posted by 69GWC View Post
Well I installed a new tach, new headlight switch, E-brake handle, acc plate over the key, door lock pulls, larger bulbs in the dash, painted the needles and polished the lens.
Hey did you stain the wood black on your steering wheel?
Shawn
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
shawno72 is offline
Old 09-23-2012, 04:53 PM   #4912
jc70chevy
jc70chevy's Avatar
uneasyrider thats smart i never would have thought of that... only if i had a high mount tunnel
jc70chevy is offline
Old 09-23-2012, 05:49 PM   #4913
bsteele
I went to auto fair yesterday and bought new aluminum radiator, headlight bezels, door lock and key switch kit(one key), and the blazer tank conversion. Special thanks goes out to Jason at Daves Truck Parts for being so helpful. He was able to answer all of my questions and questions my brother had for his '65. I can't wait to get the truck back from the shop that is putting on my new heads. So ready to burn the back tires off of this thing!!!!
bsteele is offline
Old 09-23-2012, 06:00 PM   #4914
69GWC
Why yes I did Shawno72 , I don't have any other would trim on my truck and did not want the wood look (but liked the stlye of the wheel) that it had so I bought some black stain and re-did it.
69GWC is offline
Old 09-23-2012, 06:40 PM   #4915
shawno72
C/10 junkie
shawno72's Avatar
I want to do the same thing. Can you tell me what kind of stain you used. Thank you.
Shawn
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
shawno72 is offline
Old 09-23-2012, 07:07 PM   #4916
Andy4639
Old member
Andy4639's Avatar
Wink Re: What did you do to your truck today!
I did a couple of things. I started by cleaning then polishing my Boss 338's with Never Dull. They look great. I wished I knew what to put on them to keep them looking good...
Then I worked on the alignment of my hood. I got it better than it was but have 2 ribets that are loose on the left side so I plan to check around and see what I can find tomorrow.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Andy4639 is offline
Old 09-23-2012, 08:37 PM   #4917
69GWC
I bought Minwax 'color express' Onyx , make sure you sand the wood well and tape off the ends of the spokes before you apply the stain I had to do mine with 2 coats.
69GWC is offline
Old 09-23-2012, 08:55 PM   #4918
74baggedbug
Did you have any problems with the inserts hitting the transmission ? I'm thinking of borrowing this idea.. Cut 2 holes and drop in some billet cup holder insets and bam I'm done!!! Thanks
74baggedbug is offline
Old 09-23-2012, 09:05 PM   #4919
69GWC
Or do the cup holders get real hot after driving awhile.?
69GWC is offline
Old 09-23-2012, 10:17 PM   #4920
mud.man.rj
mud.man.rj's Avatar
Well didn't do much to truck but clean it for a small Fall car show in our little town. A few things there, here are a few pic's.
mud.man.rj is offline
Old 09-23-2012, 11:00 PM   #4921
UNEASYRIDER
No problems mine are about 4 and a half inches deep and leaves enough space in between the tranny
Old 09-23-2012, 11:04 PM   #4922
UNEASYRIDER
Not sure yet but I did use a spray foam insulation around the cup holders and bedliner on top of that.
Old 09-23-2012, 11:42 PM   #4923
heathbirkendahl
I installed an new radio with Bluetooth to stream Pandora, stainless steel sill plates and checked my timing. Today was a good day.
Oh yeah, lady in a car looking at her phone destroys the car next to me just one lane over. Of she was in my lane it would have been me an my truck she destroyed.
1971 C/10 - Orange & White
2009 GMC 1500 - Lowered 3/4 22' KMC Slides
heathbirkendahl is offline
Old 09-24-2012, 09:55 AM   #4924
Catch_22
Catch_22's Avatar
Spent the weekend with friends who helped do a overhaul on my truck. I brought in the parts (and few runs to the store) and a very good friend from VA drove in with tools and 8 cases of craft beer unavailable in Nashville.
Top end rebuild, new intake, new carb, waterpump, fuel pump, tuneup, new radiator, fan/fan clutch/shroud and distributor rebuild. Font suspension overhaul of brakes, all bushings and ball joints tire rods, ubolts, springs and shocks and rear shocks (the rear springs will have to wait as bolts broke trying to get to them and we ran short on time)
We had some issues here and there including some broken head bolts.
Don't trust Felpro head bolts everyone. Also LMC Ubolt sizes are wrong.
Before http://i.imgur.com/CQKXM.jpg
During http://i.imgur.com/1Yo7M.jpg
Almost Done http://i.imgur.com/P9aCd.jpg
Still have a few things to do but its pretty much done. Just needs a power steering belt and some hose NTP fittings for the heater.
Catch_22 is offline
Old 09-24-2012, 10:46 AM   #4925
magwakeenercew2jh
RAT1968 '68 Cab/'71 Parts
magwakeenercew2jh's Avatar
Those are *some* friends.
Great to see the before, during, and (almost) after pics.
Nice post.
M17
Coarsegold, CA
RAT's shiny now.
But always a rat.
magwakeenercew2jh is offline
Closed Thread
