Old 09-24-2012, 12:48 PM   #6601
67cheby
67cheby
67cheby's Avatar
Re: 67 cheby's Dropmember build thread (CLOUD 9)
Thanks man, i will be there i am picking up my Sponsor/sufboard "thank you TXPINSTRIPER"
67cheby is offline   Reply With Quote
Old 09-24-2012, 12:51 PM   #6602
Xeen
Xeen's Avatar
That would be awesome if the cab was so air tight the air pressure wont allow your doors to shut, that one I would have to see for myself. Although with the level of craftmanship that has gone into this truck it wouldnt surprise me.
But wait I got jokes!
It would be kinda freaky if you were driving down the road and all the sudden you got light headed, blurry vision and impared judgement from carbon dioxide build up from lack of a fresh air supply, you might need to build a c02 scrubber.
Please call me Brian.
Check out My 1972 SWB Fleetside 5.3L Vortec Restomod Build
Xeen is offline   Reply With Quote
Old 09-24-2012, 12:51 PM   #6603
truckzilla
truckzilla's Avatar
Talking Re: 67 cheby's Dropmember build thread (CLOUD 9)
It keeps getting sweeter and sweeter!
truckzilla is offline   Reply With Quote
Old 09-24-2012, 01:19 PM   #6604
VA72C10
VA72C10
VA72C10's Avatar
Looks great! Love the blue accent lighting! Dash is incredible.
Man, how many days/hours do you have into just wiring?
good one! Not air tight, but the amount of air displaced by the door can make them hard to close....check out the gmc pauls door seals are great thread...
Old 09-24-2012, 01:59 PM   #6605
67cheby
67cheby
67cheby's Avatar
the wiring has taken alot of time, and this with using the best stuff ! It just gets really complicated when you need the Painless 18 circuit haness to talk to thePainless EFI harness to theDakota Digital dash harness to the DD Compass temp upgrade harness to the DD Gear position harness to the Spal fan harness to the Delta Hid harness to the Vintage air harness.....well you get the picture ! LOL ...#!^#%!@^%@%, if my friend John would have been there from day one...it would have taken alot less time !
Old 09-24-2012, 02:03 PM   #6606
67cheby
67cheby
67cheby's Avatar
We still have to wire the power window, power door locks and remote start !
Old 09-24-2012, 02:04 PM   #6607
screaminchevypickup
Laid Back
screaminchevypickup's Avatar
It all looks sweet mike!! Great job!!
72 chevy swb
Direct dealers for..
Vintage Air, Porterbuilt, Billet Specialties,Budnik wheels ,eddie motorsports, raceline wheels, intro wheels, Dakota Digital, precision, unisteer, Trimparts, and many many more... Laid Back Recreations.. Full restoration shop and full paint and body..
Kyle
http://67-72chevytrucks.com/vboard/s...d.php?t=574629
screaminchevypickup is offline   Reply With Quote
Old 09-24-2012, 02:05 PM   #6608
jlsanborn
jlsanborn's Avatar
And prolly ten other things you forgot and four or five things you'll re-do
Looking sweet man! We are all patiently waiting for a start-up video and that crazy bed wood!
'77 K30 3+3 - "The Crummy"
http://67-72chevytrucks.com/vboard/s...d.php?t=640134
'67 C10 L/SWB - Soon to be daily driver!
http://67-72chevytrucks.com/vboard/s...d.php?t=471776
jlsanborn is offline   Reply With Quote
Old 09-24-2012, 02:34 PM   #6609
thor
thor's Avatar
Getting caught up after a week away. Truck is looking amazing Mike! Simply amazing!
1972 Chevy Blazer CST.....Project: Polished Turd
thor is offline   Reply With Quote
Old 09-24-2012, 03:01 PM   #6610
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
I think it has more to do with the huge area of the door coming in contact with that large rubber seal and when it all squeezes in the door jamb, it makes it harder to shut. If you adjust the door out it usually helps shutting them. Trimming the weather striiping will allow an air gap, and it can move if you will when compressed. This is just my take on it.
Man the dash and head lights are sweet. I bet those puppies are super bright at night!!!!!!!
Ryan
1969 Chevy milk truck
Old 09-24-2012, 03:24 PM   #6611
big_al_71
big_al_71's Avatar
Those gauges look awesome!!!!
Get your facts first, and then you can distort them as much as you please!!!!!.
Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild
big_al_71 is offline   Reply With Quote
Old 09-24-2012, 03:30 PM   #6612
VA72C10
VA72C10
VA72C10's Avatar
Originally Posted by GMCPaul View Post
Glad you like them, I think they are the best also over the glue in style. The easiest method to install them is using a rubber mallet to tap on the seal to install it, using the rubber mallet gets them to conform best to the mitered upper corner and fully seats it on the door cab seal lip. lip. and doing it under the center of the door sill plates hides the cuts ) and it also allows any water that gets into the cab to drain You should also cut a angle notch on either end where they meet under the door sill plates so that the cuts form a inverted /\ shape this allow air to expell from the rubber bulb seal as the door closes ( this allows the doors to close much easier than if you butt the 2 ends tightly together and doing it under the center of the door sill plates hides the cuts ) and it also allows any water that gets into the cab to drain out.
For those that order our complete cab rubber kits we offer the option in the cart to upgrade from the glue on door seals to our push on version.
In years past we intially tried using the late model truck door seals such as 88-98 or 82-93 S10 but we found the bulb seal was almost 3/16" thicker than the stock seals which mean't door adjustment & latch adjustment to get them to close well using those styles, about 3 years ago though we got with our manufacturer and came up with a similar seal as the 88-98 trucks and 82-93 S10 seals that is only apprtox. 1/32"-1/16" thicker than the stock glue on seals and since then you no longer have a problem using alot of effort to close the door fully and it eliminated the need to adjust the doors to reduce the effort involved in closing the doors.
Paul @ GMCPauls
just trying to save cheby and anyone else time if it can be a simple fix vs removing the seals, adjusting the door gaps or edges, and reinstalling....it can potentially be a 30 second fix....there are others on the thread that it's worked for...
Old 09-24-2012, 03:35 PM   #6613
watahyahknow
watahyahknow's Avatar
think there are some higher class cars (mercedes?) that used vacuum to help close the doors
i got a job again and having fun at it too
idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real
i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts
watahyahknow is offline   Reply With Quote
Old 09-24-2012, 04:16 PM   #6614
Custom 68
Custom 68's Avatar
my bosses slk will automatically roll the windows down about an inch when teh door is opened then when closed it will rollup tight.
Dave
1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap
1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?)
"A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome".
"If it doesn't fit force it...If it breaks then it needed to be replaced anyway!"
Custom 68 is offline   Reply With Quote
Old 09-24-2012, 04:23 PM   #6615
Lolyin58
Lolyin58's Avatar
Looking sweet Mike!!
Lolyin58 is offline   Reply With Quote
Old 09-24-2012, 04:54 PM   #6616
lolife99
67-72 parts collector,…
lolife99's Avatar
Congrats Mike.
Saw your concept drawing in the Nov. 2012 issue of StreetTrucks Magazine.
Keith
Convert to disc brakes.
Old 09-24-2012, 05:01 PM   #6617
67cheby
67cheby
67cheby's Avatar
AWESOME.....so it is out ? or did you get a sneek preview ??
Old 09-24-2012, 05:02 PM   #6618
VA72C10
VA72C10
VA72C10's Avatar
Congrats Mike.
cool!
any chance you can scan it (or someone else can?) quickly checked their fb page and website with no success...
Old 09-24-2012, 05:03 PM   #6619
67cheby
67cheby
67cheby's Avatar
Thanks VA72C10 !
Old 09-24-2012, 05:05 PM   #6620
VA72C10
VA72C10
VA72C10's Avatar
so Mike...did you cut the notch in your weatherstrip yet?
Old 09-24-2012, 05:11 PM   #6621
67cheby
67cheby
67cheby's Avatar
yes i did when i installed it !
Old 09-24-2012, 05:16 PM   #6622
67cheby
67cheby
67cheby's Avatar
SO............... should i post the rendering i sent them......or wait for the Street Trucks pic to come out ????
Old 09-24-2012, 05:29 PM   #6623
VA72C10
VA72C10
VA72C10's Avatar
Did you have to ask???
It's out there....post it up!!!
Old 09-24-2012, 05:30 PM   #6624
VA72C10
VA72C10
VA72C10's Avatar
hmmm...guess you will have to tweak things a bit...or just see if they get easier to close as you use them...
...or keep slamming them....
Old 09-24-2012, 05:32 PM   #6625
67cheby
67cheby
67cheby's Avatar
SLAM them i wish .....i have to do a full body tackle just to close them !!
fiberglass inner fenders, pb hood hinges ", w/pb 4 link
