09-24-2012, 09:43 PM | #1 |
How to change gauge cluster bulbs?
Does the cluster have to come out or can the bulbs be changed from reaching under the dash?
Posted via Mobile Device |
09-24-2012, 09:46 PM | #2 |
Re: How to change gauge cluster bulbs?
Also interested to know on this one.
09-24-2012, 09:48 PM | #3 |
Most can be changed by reaching up behind the dash, look for black twist out sockets.
09-24-2012, 09:54 PM | #4 |
Yeah, if you get up behind there you can change most from behind the cluster without removing it. I've got a left turn signal light that needs to be changed and I grabbed the bulb listed as the correct part, but it does not feel like it seats properly. I've gotten it to stay inside the receptacle, but when i hit the left turn signal the light won't flash. I'm wondering if it needs to be seated behind to gauge cluster to ground it and get it to work?
1970 lwb hugger orange. 454 duel fuel cng and gasoline. 1990 Ford F-250 Lariat 2008 Mazda3 |
09-24-2012, 10:01 PM | #5 |
Hmm. Are they not all the same ??
09-24-2012, 10:06 PM | #6 |
as far as i've seen they are listed to be the same.
09-24-2012, 10:08 PM | #7 |
From what I've read most of the gauges should be the 194 style bulbs. I ordered some 7-LED replacements off of ebay that should be here any day.
09-24-2012, 10:10 PM | #8 |
let us know how you like the LED replacements, maybe throw up some pics?
how much did they set you back? Even with the bulbs in place I've never liked how dim the display has been at night.
09-24-2012, 10:20 PM | #9 |
The shipping was more than the bulbs. I got 10 for $3. I'll let you know if they are any good. I'm with you on the dim stock display.
09-24-2012, 10:25 PM | #10 |
Yea. I bought 5 packs of the 194's at Walmart. For like $1.95 for each. Each pack brings 2.
09-24-2012, 10:26 PM | #11 |
I wondered if you could put something brighter in... love to see how they work.
really clean 72! http://67-72chevytrucks.com/vboard/showthread.php?t=531183[/url] also 1972 2wd blaze. |
09-24-2012, 10:30 PM | #12 |
VA72C10
The bulbs have to be seated for a good ground.
There is one bulb holder connected to a fiber optic cable for steering columns with the fiber optic indicators... To make it brighter you can paint the inner tins white or reflective silver. Posted via Mobile Device
Looking for a 67-72 swb or blazer project in or around VA. |
