09-25-2012, 03:25 AM | #1 |
C60 questions...
For a very long time I've wanted to put a regular 8 foot bed on a 70s/80s C60, and I think it's finally time to start shopping for one. I'm not really sure what I'm looking for though, I have a few questions:
Did they come from the factory as a crew cab? I know I've seen them, not sure if they were custom. Is it true they use a different cab than the smaller trucks? Same doors and dash? Did they come from the factory with an automatic trans? If not, would a TH400 be as easy of a swap as it would be in a smaller truck? Did they come in 4WD? Do they all have air brakes?
'73 K20 Cheyenne Super Camper Special 350/TH350/NP205 sittin' on 33's. You can set my truck on fire and roll it down a hill, and I still wouldn't trade it for a Coupe de Ville. |
09-25-2012, 05:00 AM | #2 | |
Re: C60 questions...
09-25-2012, 05:05 AM | #3 |
A few more.
09-25-2012, 08:25 AM | #4 |
My 87 C6500 (GMC) uses the same doors, windshield, and dash pad as my 87 R10 Chevy.
My GVW is under 26K so no CDL required. 4 wheel disc brakes with hydroboost. Dual axles and air brakes are options, as is a crew cab. My rear window is smaller - same stampuing as a pickup but different hole cut out. Cabs mount different - floor and firewall are different - depending upon which front (mine is short tilt) the lower front of the cab may be different (fenders behind the wheel are part of the cab, the rest of the fenders and hood are 1 piece SMC). Notice the different hood/fender between the last one on the first post and the first one on the next post. 4wd is an option but uncommon, C65's often have dual axles in back, have sen them with tag (lift axle) options. Many differnet engines and trans', usually 5 speed with or without 2 speed rear, Allison auto optional, 350 SBC, 366/427 tall BBC, 8.2 Detroit, Cat diesels, and I'm sure there are others. Be aware that parking brakes are usually on the prop shaft. Seat mounts are different too. My 87 has the 70's style dash with manual choke, old style column and wheel, wipers on the dash.
1987 2 ton 1982 250/TH350 beater in progress Dad's 1981 3/4 L6 3 on tree posi and no options, awaiting restoration or scrapping Plus a mess o' tractors Last edited by D13; 09-25-2012 at 08:31 AM. |
09-26-2012, 12:49 AM | #5 |
Ooooo! Now I want a Brigadier! GM sure got their moneys worth out of the machine that made those doors!
09-26-2012, 06:58 AM | #6 | |
The edges kept getting rounder and rounder as the tooling wore out; if we kept going they'd be a big round ball by now.... K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
09-26-2012, 06:59 AM | #7 |
Dooley! You cracked me up with that pic of the 7/11 truck -
K
09-26-2012, 08:08 AM | #8 |
Dumb question - if I find a truck over 26k GVW do I have to have a CDL to drive it, if I'm not using it for commercial purposes?
09-26-2012, 08:35 AM | #9 |
09-26-2012, 09:34 AM | #10 | |
K
09-26-2012, 09:37 AM | #11 | |
K
09-27-2012, 05:41 PM | #12 | |
A build pic found on the net. (7-11)Don't remember where I got the pic originally. Former 26' UHAUL unit. |
01-26-2013, 06:56 PM | #13 | |
07-28-2013, 09:00 AM | #14 |
Does anyone know if the 73-89 style regular pickup cabs themselves are interchangable with the C50-60-70 trucks?
