Old 09-25-2012, 07:45 PM   #1
rkintn_68
rkintn_68's Avatar
GMC vs CHEVY ???
I am new here and to body work .
I have a question and I have read for days on this forum and can not really understand or figure out the answers to these ???'s
Are the cabs,cowls,and doors on all years 67 thru 72 GMC & CHEVY the same
shape , size ,ect .? enterchangeable with each year ?
I think I understand that the hoods and fenders did change shape from 69 to 70 ?
How far off are the average aftermarket body parts from the original ?
rkintn_68 is offline   Reply With Quote
Old 09-25-2012, 07:54 PM   #2
sean1969c10
sean1969c10's Avatar
Re: GMC vs CHEVY ???
As far as I know, the cabs, cowls and doors are the same. GMC fenders are the same as the 67-68 Chevy. 68 and later GMCs having marker lights like a 68 Chevy. If I'm wrong someone will correct me but this is my understanding.
Sean
"If your gonna be dumb, you gotta be tough"
1960 Chevy Impala Sedan - my 25 year search is over!!
1969 C-10 longbed - Nice day DD
1970 Chevy Nova - Street and Strip Project
2002 Acura MDX my DD
2007 Honda Odssey - My Wife's "Mommy Van"
sean1969c10 is offline   Reply With Quote
Old 09-25-2012, 07:58 PM   #3
Tomahawk30
Tomahawk30's Avatar
The 72 doors are slightly different than the earlier years, but are still essentially interchangeable with the others. I think the only differences are the length of the studs for the window and door handles, and there's an extra screw for the wing window on the inside.
1979 Silverado C10 Shortbox - Photo Album
1977 Silverado K20 Camper Special - Photo Album
1972 C10 Custom Deluxe Highlander - sold
1971 Cheyenne Super Longhorn -sold
1972 Cheyenne Super SWB 4x4 -sold, bought back, sold again... I'm dumb.
1970 Chevy C10 SWB "Sprout" -sold
1972 Cheyenne K20 -sold
1969 GMC Shortbox Stepside 4x4 -sold
1972 GMC Jimmy 4x4 -sold
Tomahawk30 is offline   Reply With Quote
Old 09-25-2012, 08:02 PM   #4
sean1969c10
Yes I forgot about the 72's doors, they will bolt up and fit but the details inside are different due to the plastic door panels.
Sean
Old 09-25-2012, 09:05 PM   #5
rkintn_68
rkintn_68's Avatar
So can you put 67 front parts on a 72 cab ?
Old 09-25-2012, 09:11 PM   #6
71swb4x4
71swb4x4's Avatar
Absolutely. It's common for people to swap their favorite front end on their 67-72 GM truck.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 09-25-2012, 09:51 PM   #7
Ask about a specific interchange and we'll tell you what's involved.
Old 09-25-2012, 10:38 PM   #8
Andy4639
Old member
Andy4639's Avatar
Wink Re: GMC vs CHEVY ???
For the most part yes parts interchange on all these models.
But there are differances in them as the 72 doors.
To put a 67 front end on a 72 cab, yes u can do it but you need all of the 67 front end core support fenders hood everything.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 09-25-2012, 10:56 PM   #9
Tinkermc
did you get enough or still need answers?
Tinkermc is offline   Reply With Quote
Old 09-25-2012, 11:11 PM   #10
50bomb
50bomb's Avatar
Will a 67-68 gmc hood work on a 67 chevy truck front end?
Stovebolt-It is painted
50bomb is offline   Reply With Quote
Old 09-25-2012, 11:32 PM   #11
71swb4x4
71swb4x4's Avatar
EXACTLY the same hood.
Old 09-25-2012, 11:39 PM   #12
50bomb
50bomb's Avatar
Originally Posted by 71swb4x4 View Post
exactly the same hood.
thank you!
Old 09-26-2012, 07:50 AM   #13
rkintn_68
rkintn_68's Avatar
Thanks guys , here is wat I got going on , a 72 GMC cab , and the whole front
of a 68 chevy in afternarket pieces from LMC ... I have got a lot of ajustment
here to make this work as you can see in the pics ... the hood is not fitting or
lineing up ... It looks like the hood has more arch to it, than the fenders ...
Old 09-26-2012, 08:26 AM   #14
First of all,did you get a 67/68 radiator core support and use the 67/68 mounts for it? Second,unfortunately the aftermarket parts are not made very well. The fenders are to flat on top and don't follow the contour of the hood. There's issues with matching the contour of the doors,too. It looks like you need to bring the cowl cover up. and the hood down. The hood springs may need a tweak and/or just adjustment mounting to the hood. Are you sitting on an original 4wd frame? Did you use 4wd cab cushions?
Old 09-26-2012, 08:49 AM   #15
rkintn_68
rkintn_68's Avatar
Yes i have the 67/68 core support , and mounts , yes on a 72 GMC K 1500
frame and cab , you are right about the aftermarket stuff not the same, i agree
the match to the doors and cab not perfect but the hood i can not live with ...
Will try some new hinges and tweak a little more ... I will probably try and
get a stock hood without the cowl ... Or maybe just shop around for the original
72 front end parts ... That wat it all about for me , something to play with ...
Old 09-26-2012, 09:25 AM   #16
raggedjim
raggedjim's Avatar
Yeah, the cowl hoods are tricky, some are better than others, even from the same supplier. If you start looking for a 67-68 flat hood I believe I have a couple.
I'm in Murray Ky
Good luck, Rg
raggedjim is offline   Reply With Quote
Old 09-26-2012, 09:39 AM   #17
If you give up on the repro stuff,maybe find yourself some '68 Chevy/68-72 GMC fenders. At east then you'll have something good to eye the hood up with. If it still won't fit well enough,then go to original hood. We put together a '68 with all new sheetmetal clip,including cowl hood.This was "the good stuff" and we had similar problems. We got it pretty good after a lot of work,but the fenders are just not right. The only problem we had with the hood was at the back of the "rise" both sides were completely different. One went straight up and the other had a slant. How the heck does that pass? With hoods it doesn't take much for one to get tweaked in shipping/handling. They come from very far away,like about everything these days ):. Yours almost looks bowed up like the sides at the back are pinched in. Ain't it great?
Old 09-26-2012, 09:47 AM   #18
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
Keep in mind that the factory did not do a great job of alignment on these trucks when new.But certainly better than what you got.The adjustment and alignment of body panels is one of the things that make a big difference between a good looking truck and a great looking one.Also after 40+ years,there's some settling.tweaking etc. of a truck.Using parts from more tha one and/or aftermarket means they didn't "grow" together.
I don't think I have the patience or skill to do great bodywork.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 09-26-2012, 07:43 PM   #19
rkintn_68
rkintn_68's Avatar
I'm in Murray Ky
Good luck, Rg
can you pm me and maybe some pics ? i dont live but a hour from you , i think ?
Old 09-26-2012, 07:49 PM   #20
rkintn_68
rkintn_68's Avatar
I hear ya !!! Live and learn ... I wanted one these trucks and thought I was
on a good one but still for the money I paid for it and if I have to redo it
still be in good shape ... Its still a project in motion !!! Thanks ...
Old 09-26-2012, 07:53 PM   #21
rkintn_68
rkintn_68's Avatar
I am with ya on that ... I believe the hood is arched or maybe the fenders are
not arched enough, hard to make chicken salad out of chicken , you know !!!
I appreciate your advice ... Thanks
Old 09-26-2012, 08:31 PM   #22
Andy4639
Old member
Andy4639's Avatar
Is the hood bolted down are just sitting there? The hood to cowl gap is way to close. U need about a 1/4" gad there and the hinges maybe holding the hood up. Does the cowl have any shims under it before it was bolted down?
As stated new metal parts are tuff to get good gaps and when I say good gaps I mean anything from 1/4" to 1/2" depending on what part it is with out body work. Good luck with it though and just take your time.
Old 09-26-2012, 08:52 PM   #23
rkintn_68
rkintn_68's Avatar
Hood is bolted to hinges and hinges are bolted ...The cowl does have shimms
on the passenger side and is fastened back to cab as far back as it will go.
thanks
Old 09-27-2012, 12:00 AM   #24
Square_78
Square_78's Avatar
You didnt do any body panel alignment or fitting before you painted everything?
#teamlongbed
"I refuse to go disc brakes. I actually love drum brakes. It makes for an adventure." - 50bomb
1978 Chevy shop truck - static 6/8"
1970 GMC 1500 - Accuair eLevel Resto-mod http://67-72chevytrucks.com/vboard/s...d.php?t=537497
Square_78 is offline   Reply With Quote
Old 09-27-2012, 12:22 AM   #25
rkintn_68
rkintn_68's Avatar
I purchased the truck from ebay , it was not completed , the po
did the paint and body work . after an 8 hr drive with trailer to
pick up truck he did not have the hood latch on ... he said all
was good , i took his word for it , got it home and put latch on
and this is wat i got stuck with , that was my question for him
after the fact ... here is a pic of wat i bought ... still did not pay
a lot for it ... so not a big loss ...
