Re: 1963 C-10 in NC
Are you talking about the cab vents? You will have to find a set of 60-61 cab vents that were cable pull operated. Ive got a couple contacts that might hav ethem. Usually you can get them for around $40-60. The cable pull vents are the same size as the manually operated vents and will fit in the stock location. The cables attach to the vents and the cable bracket is just mounted under the dash. I can take them out if you need some pics for illustration, but its actually an easy job. The vent screens are optional. I didnt have a set for a year and they work just fine, although I do notice better flow with them...and it makes them look much cleaner. Let me know where I can help
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
