Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1967 - 1972 Chevy/GMC Suburbans & Panels Message Board > 1967 - 1972 Chevy/GMC Suburbans and PanelsProjects and Builds
Old 09-18-2012, 11:37 PM   #401
dbomb53
dbomb53's Avatar
Re: 68 Burb... here we go!!
Nova is bad A$$, now stop with the talk and get some pics up of the burb! haha....
"I wanna be like Dino when I grow up"
dbomb53 is offline   Reply With Quote
Old 09-26-2012, 01:31 PM   #402
CLTBurban
CLTBurban's Avatar
Hey Juan,
Any chance of getting some pic's of the Scott's tank you mentioned in one of the other threads? I'm very interested in doing the same thing with my burb, but wanted to see how you had it setup after shortening the filler neck and all. Thanks, as always!!!
'72 GMC Suburban 1/2 Ton (Red)
'68 C10 Short Fleet (OG 503 Light Green and Patina)
'70 C30 Dually (OG City of Charlotte Welding Truck)
Past 67-72's Chevy Trucks
'68 C10 Short Fleet on 20" Coy's, '72 C20 Suburban (Ochre Big Block), '69 C20 Suburban (Silver), '69 C10 Suburban (Red/White on Boyd's), '72 C10 Short Fleet (Ochre on Torq's), '70 C10 Short Fleet (POS)
CLTBurban is offline   Reply With Quote
Old 09-26-2012, 03:58 PM   #403
jmedero
jmedero's Avatar
He clt the tank hangs down 5 inches below the frame in "prebuilt" form. Justin said he can weld the mounting tabs higher or lower on the tank to clear your specs. I'll post a pic of the tank as soon as I can.
68 BB burb build thread Scott's super slam front/rear
http://67-72chevytrucks.com/vboard/s...d.php?t=378084
jmedero is offline   Reply With Quote
Old 09-26-2012, 04:05 PM   #404
jmedero
jmedero's Avatar
Pulled the frame out to clean it up and paint it. Also going to run my air lines and brake lines while I'm at it.
Old 09-26-2012, 08:17 PM   #405
CLTBurban
CLTBurban's Avatar
^^^^^^ very cool!
Old 09-26-2012, 08:19 PM   #406
CLTBurban
CLTBurban's Avatar
I'm trying to gather the nerve to separate my body from the frame. Difficult? Tricks or tips you can give us?
Old 09-26-2012, 11:07 PM   #407
jmedero
jmedero's Avatar
It wasn't bad really. Me and a buddy did it in about 45 min. The pita part is the rear body mounts that love to spin in the wood. If you have not notched the rear yet you'll be good. I had to lift the body up sooo high to get the frame notches to clear the floor board.
Go for it man.
Old 09-26-2012, 11:30 PM   #408
CLTBurban
CLTBurban's Avatar
Cool. She's not notched (yet), but she will be by the time the frame rolls back under. I'll definitely need to compensate for the height difference. Thanks, as always!
Old 12-10-2012, 10:29 PM   #409
jmedero
jmedero's Avatar
Well finally got power out at the new shop. Got all of the electrical finished. I'm waiting on a new electric start motor for my air compressor. Still have some exterior trim to go up on shop as well. Very stoked.
Got my new bridge worked out today. Cut and fitted the pieces in. Ill weld them in tonight when everyone goes to sleep, ill go play.
What do you think of the bag plates?
Old 12-10-2012, 10:38 PM   #410
Hart_Rod
Hart_Rod's Avatar
Sweet! Progress in your future I see...
Hart_Rod is offline   Reply With Quote
Old 12-10-2012, 11:09 PM   #411
jmedero
jmedero's Avatar
Thanks master yoda
Old 12-11-2012, 08:31 AM   #412
blfuller123
blfuller123's Avatar
Looking good
blfuller123 is offline   Reply With Quote
Old 12-11-2012, 08:34 AM   #413
raull
raull's Avatar
nice and bright in there !!!! plates are coming out nice also !!!
check out my build thread
71 c/10 step side 5.3 twin turbo
http://67-72chevytrucks.com/vboard/s...d.php?t=485320
raul
raull is offline   Reply With Quote
Old 12-11-2012, 11:20 PM   #414
Splash4195
Nice Build!
Splash4195 is offline   Reply With Quote
Old 12-11-2012, 11:24 PM   #415
jmedero
jmedero's Avatar
Thanks splash.
Old 01-03-2013, 01:27 AM   #416
jmedero
jmedero's Avatar
Ok got the rear susp all done. I started cleaning and prepping the frame for a good coat of paint. Then it's time to run brake lines, gas lines and I'm going to give the SS air lines a try. From what I've read the ss lines grab and hold on in the air fittings really good. Hoping to roll it out is the shop this weekend and power wash it all down and start painting it. I'm so ready to be done with this part of the build.
I need a picture to see what the rear of the frame is sup to look like. I removed the hitch the PO had put in there and need to see the rear most section of the frame and the bumper brackets. If you have some pics feel free to post them up.
Old 01-13-2013, 01:24 AM   #417
jmedero
jmedero's Avatar
All painted. I hope to start running lines next week. She rolled out of the garage for a good scrub down today. Then drip dry while I cleaned the shop up. The milk crates worked out good to get it off the ground so I could clean it all up.
Thinking of what coating to do on the underside of the Burb? Should it be done before frame goes back under it?
Old 01-13-2013, 09:03 AM   #418
Hart_Rod
Hart_Rod's Avatar
Looks good! Do the undercoatingi before you put it back on the frame.....
Old 01-13-2013, 10:09 AM   #419
jmedero
jmedero's Avatar
Which kind should I use? I used por15 on the nova. Any suggestions?
Old 01-13-2013, 10:17 AM   #420
Hart_Rod
Hart_Rod's Avatar
Por will probably be the easiest. I would do that and then possibly rattle can some rubberized undercoating.
Old 01-13-2013, 11:42 PM   #421
jmedero
jmedero's Avatar
Will do master yoda.
Old 01-14-2013, 10:18 AM   #422
raull
raull's Avatar
Looking good bud !!! Love the shop area !!!
raul
Old 01-14-2013, 10:22 PM   #423
jmedero
jmedero's Avatar
Thanks man. Prob won't be till Thursday before I can get out there again.
Old 01-18-2013, 10:50 PM   #424
sunk99
sunk99's Avatar
Signing on here, Burb is looking nice.I'm waiting to get mine back from metal working shop now.
sunk99 is offline   Reply With Quote
Old 01-21-2013, 12:05 AM   #425
Bagood
looking good !!!!!!!!
Bagood is offline   Reply With Quote
