Old 09-26-2012, 09:39 PM   #1
crewcabshorty
crewcabshorty's Avatar
dana 60 questions
i am installing a 4 inch skyjacker lift on my 1988 ccsb . my question is on the passengerside of the dana 60, there are two bolts that go into the housing instead of u bolts . should i use studs instead of bolts to secure the thicker leaf springs ?
crewcabshorty is offline   Reply With Quote
Old 09-26-2012, 10:49 PM   #2
GSP7
GSP7's Avatar
Re: dana 60 questions
Sounds like a good Idea
GSP7 is offline   Reply With Quote
Old 09-27-2012, 12:48 AM   #3
Mr. 250r
Mr. 250r's Avatar
I kept the bolts and beat the crap out of my front end by ramping it and slamming it down but that's just my experience, i have seen people convert them to studs because they either had them break or think its going to break
1987 Chevy V30 - http://67-72chevytrucks.com/vboard/s...d.php?t=573854
1988 IROC-Z Camaro - 305/T5 T-Top
1989 GMC V35 - Marbolo Express http://67-72chevytrucks.com/vboard/s...d.php?t=596850
1991 V2500 Suburban Silverado - Sold
1991 V2500 Suburban Scottsdale - Big Nasty http://67-72chevytrucks.com/vboard/s...d.php?t=497423
2001 Ram 3500 5.9 H.O NV56 EC DRW - Sold
2003 1500 Silverado
2004 Ram 3500 5.9 H.O NV56 CC DRW - Sold
2005 Silverado 2500HD 6.6/ZF6 CC LWB
Mr. 250r is offline   Reply With Quote
Old 09-27-2012, 01:54 AM   #4
Chevy1TonFun
Grease Monkey
Chevy1TonFun's Avatar
When I swapped to my Dana 60 I used studs.
Tow Rig: 2012 Chevy 2500HD CCSB LTZ Z71 4x4 Duramax
Ultimate Offroad Build: 1978 Chevy Silverado K30 Crewcab Build Link http://67-72chevytrucks.com/vboard/s...d.php?t=654053
Mud Truck: 1972 Chevy Cheyenne K30 4x4, 468/400/205, D60/D70HD, 18" Custom Lift, 17x39" IROKs
FOR SALE http://67-72chevytrucks.com/vboard/c...ton-4x4&cat=12
Chevy1TonFun is offline   Reply With Quote
Old 09-27-2012, 08:23 AM   #5
OLDCHEV4X4
OLDCHEV4X4's Avatar
Studs.
If the bolt is a little too long, and tightens up in the hole before the spring top plate, then the springs can move around.
If the bolt is a little too short, then it could strip out the threads in the housing when you torque it down.
For maximum thread engagement and strength, use studs.
72 k/10 short wideside
72 k/5 Blazer
72 K/5 Blazer - obstacle course racer
72 custom/10 8' bed
70 K/5 Blazer
67 C-30 GMC Flat bed
86 GMC K2500 Plow Truck
85 GMC K3500
84 M1008
85 M1008
77 G30 Motor Home
72 Sears 12hp Tractor
Glenmoore, Pennsylvania
OLDCHEV4X4 is offline   Reply With Quote
Old 09-27-2012, 08:26 AM   #6
jjzepplin
jjzepplin's Avatar
Ok. So I was in an accident and the studs broke. I cannot find any new ones without buying the whole bolt kit. Any one got any or a source for some good ones. I have bolts in now but have not driven it yet. Sorry to hijack crewcabshorty but this info will help you too.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
Old 09-27-2012, 08:26 AM   #7
V30 mongo
Try an industrial supply house. Measure the leanth of the new bolt required an see if you can get grade 8 shoulder bolts. They will be stronger than most studs, and remember if you use a stud type fastener the nut must be of equal strength.
V30 mongo is offline   Reply With Quote
Old 09-27-2012, 08:33 AM   #8
OLDCHEV4X4
OLDCHEV4X4's Avatar
Any drive line, drive shaft, spring shop will have them.
72 k/5 Blazer
72 custom/10 8' bed
70 K/5 Blazer
85 GMC K3500
84 M1008
85 M1008
77 G30 Motor Home
Old 09-27-2012, 10:46 AM   #9
OLDCHEV4X4
OLDCHEV4X4's Avatar
McMaster Carr has 5/8-11 grade 8 threaded rod 3' long for $13.43. I didn't see the tall gr 8 nuts though. And I didn't look for the washers.
But by the time you order all that and shipping, you my as well order the u bolt and stud kit for a D60.
72 k/5 Blazer
72 custom/10 8' bed
70 K/5 Blazer
85 GMC K3500
84 M1008
85 M1008
77 G30 Motor Home
Old 09-28-2012, 09:44 AM   #10
obijuan
Offroad design will sell you just the studs.
obijuan is offline   Reply With Quote
Old 09-28-2012, 10:07 AM   #11
b454rat
Any suspension place should have or either make the u-bolt, and I went to hardware store and got the threaded rod. Cleaned the threads in the axle, threaded the rod all the way, tightened it then cut off where I has some extra thread. Never had an issue.
2000 GMC CCSB 454/4L80 6” lift SAS
1999 Chevy CCSB 454/NV4500 4” SAS
1999 GMC Yukon 350/4L60 6" SAS
Old 09-28-2012, 10:30 AM   #12
OLDCHEV4X4
OLDCHEV4X4's Avatar
He just needs the studs, not the u bolts.
Most hardware stores don't carry grade 8 threaded rod that big.
72 k/5 Blazer
72 custom/10 8' bed
70 K/5 Blazer
85 GMC K3500
84 M1008
85 M1008
77 G30 Motor Home
