#26 |
Re: What spare parts would you take on an 800 mile drive?
I second putting parts on before you go. Check everything over. If you've had one of these trucks long enough you can listen and tell whats right and whats wrong.
1985 C10 Custom Deluxe LWB 305/700r4 [ Goldfinger ] ![]() 1999 k3500 crew cab dually 6.5tdi/4l80e |
#27 |
Get in and drive. You should be just as confident in your older truck as you are a new vehicle. To me there should be no difference. If your truck is well maintained and in good running condition you shouldn't have to worry about stuff like this. Just my opinion I guess. Why do some thing they need to bring half the garage on a long trip? Be positive and enjoy the ride.
RIZ |
#28 |
Triple A, money, water, and tools. Also "common cents" like cell, and blankets
Posted via Mobile Device |
#29 | |
#30 | |
If I ever break down in my classic car, I'm pretty confident I can fix it on the side of the road, it only needs fuel and spark to run. If I have anything questionable, I might carry an extra set of points and plugs, maybe a fuel pump, but nothing extreme. I've criss crossed the country several times in this old stuff, never once did I have a single issue. Just get out there and enjoy the scenery and don't worry about it. 800 miles is nothing. My wife is putting more than that on her car every week. |
#31 |
i just took a road trip to california in my 01 buick put 6000 miles on it in two weeks. brought booster cables a spare and cash
85 swb c10 6/6 drop 83 c10 bagged and sfbd project |
#32 |
in the middle of a 1000 mile trip and all i got is my phone. parts before to put on yes. always. but if you are good a bout rutine stuff you should be fine. bring water and oil spare and a tool kit. the tool kit i keep in my truck at all times as i am the one that fixes everything so i allways have tools. i like to just clear my mind and drive
1986 c20 "the hillbilly" 350 sm465 3.42gears 21mpg at 70mph 1985 k30 "the ice cream truck from hell" no rust az truck 197-8??? c30 "ramp truck" 454 1978 monte carlo 350 350th with 2.73 gears. no rust. sc car |
#33 |
#34 |
Well I stopped in nor cal on my way to visit my grandma, and the tranny started acting up again,with less than 1,000 miles on a new filter, fluid, rear main seal and modular i figure rather than dumping more money into fixing one thing at a time its time for a full rebuild . So as it sits now I just barely finished pulling the tranny, found a shop in Reno, Nv by the name of valley transmission that is gonna do a full rebuild for 700, called a couple shops in town and this seems about ballpark range, yelped and angioe listed the shop, seems to have a great reputation. Dropping it off tomorrow and should ghave it back by Wednesday, ill keep you guys updated.
#35 |
Just noticed you live in Truckee??
I have family in Reno and Sac. You're right smack in the middle ![]() Sorry to hear about the trans, unfortunately you can't pack one of those with you ![]() |
#36 | |
#37 | |
![]() I've been through Chico (north of Sac) on my way to the redwoods. Nice areas up there. |
#38 | |
![]() Join Date: Mar 2009
'80 SRW C35 - 355/700R4/4:11/2.5-3/DD '77 Cheyenne K5 - Roller cam 355/NV4500/205/4:88's/35's/DD rust repair on the '77 http://67-72chevytrucks.com/vboard/s...d.php?t=740291 |
#39 |
I read one time that the number 1 cause of hiway breakdown's was cooling system failures. I'd check radiator,hose's and belt's too. And the tool's, water,duct tape and all size's of zip ties. Zip ties have saved the day for me.
" Never look up a dead dogs butt." ![]() |
#40 |
Well got the transmission back from the shop this morning, then put it in this afternoon, so far so good ive put about 30 miles on it and it is running great! Off to Utah on friday.
#41 |
Junior Member
It doesn't matter. It always seems that what I take is not what breaks.
I let my 16 year old son drive my every car that I own. I don't let him drive my truck. A man has to draw a line somewhere. |
#42 |
Good luck on your trip thinking about doing the same thing myself next month San diego, Ca to Martinez, Ca. I am in the Bay Area also. Not really sure of your set-up serpentine or v-belt, but I highly suggest take a set belts just a case they jump. Ignition module if you have hei (should be 4-pin) they are cheap just if the truck doesn't want to start on you. You will be fine with this set (Craftsman24 pc. 6 pt. Standard Easy Read 3/8 in. Dr. Socket Wrench Set $59.49) that will be plenty fits right behind the seat. (Craftsman12 pc. Standard 12 pt. Combination Wrench Set $25.49) that will take care of your tools. Extra water for you and the truck lol. little 5 gal gas can just in case. Piece of carboard if you have to get under the truck. You should be good though as long the truck is ready to roll.
