HELP FAST PLEASE! How do I get a front fender off a C10 FAST?!?!
Where are the bolts and what size sockets do I need? A friend of mine just got a C10 in his shop, but he said if I wanted anything off of it, I have to get it before 2moro morning. The fenders are PERFECT, so I'm gonna yank em. I seen that there's 4 bolts on the radiator core support, and then 2 behind the door (only accessible when door is OPEN). Where are the rest?
Professional Grade
On the 76 there was one on the door, one under the body attached to the cab, some along the inside of the fenders, and along the inside of the rad support.
Just keep pulling bolts till you get it. You'll be needing 1/2 and 9/16 sockets, and at least a couple hours to get them.
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap) |
Slots go on anything!
there is a 9/16 headed bolt on the backside of the fender, behind the wheel. there are also two 1/2 headed bolts that hold the valence panel to the fender in the front. Take a 1/2 and 9/16 sockets, an extension, and ratchet. That should get the fenders off. BTW, there are 2 9/16 bolts that hold the inner fenders to the cab, if you are taking them too. If not, there are 6 (I think) bolts in the wheel opening, and 4 at the front of the inner, all 1/2 head
1974 Jimmy- 5.3/4L80e/NP241 |
Professional Grade
Jonboy, the link under your name doesn't work
![]() ![]() 1/2, 9/16, and an extension with some patience will getcha new fenders =)
#5 | |
penetrating oil
dont forget to grab some wd 40 or something it will help save some time
79 chevy k20 350/350/205/D44/14bFF 4.56 gears rock ![]() LWB pimer black 01 S-10 ZR2 extended cab 4.3/4L60E/233 3.73 gear 31" DICK CEPEK CRUSHERS |
Professional Grade
you can do it in 10 minutes if you really want it
#8 | |
Professional Grade
Why are you still here?! GO GO GO
#10 | |
#11 | |
Gary -1986 SWB: lowered 4/6, SOLD!!! -Best 1/4 mile: 14.51 @ 91.01 MPH -2001 Pewter Tahoe, billet grill, Corsa Sport Cat-back, K&N FIPK SOLD!!! -2004 Z-71 Extended cab with a flowmaster, BDS 6.5", 3" BL, 35x12.5x18 Trail Grapplers on Pro-Comp 18x9 wheels |
this sounds legal.....not
'51 F100, backhalf with a narrowed 9 and coil overs, 18.5" mickeys, monte front clip, +400" sbc in the works '05 1500 Crew Cab RIP '84 swb 5/7 drop, solid cammed 408 w/ fully ported dart heads, th350 w/ 10 inch hughes, 12 bolt w/ 3.73 richmonds and a locker '80 swb 4x4 in progress: 7" lift, 350 th350/np205, d44 and 1.5" ORD tie rod, 14BFF w/discs , armored diff covers, 40" MTR's |
#13 | |
#14 | |
#15 |
sounds like the 83 cutlass we turned into a convertable (sawzall) and then left on the side of the road after we broke it off roading. i was actualy figureing that the truck had been wrecked and he was letting you grab the fenders before the insurance company got the truck, lol.
#16 | |
#17 |
Oh,you can't buy that new
![]() Join Date: Apr 2000
tim, take some extensions and a swivel if you have it . a few of the ones on the front behind the headlight bezel can be a hassle w/o the right tools. there are 2 way up high behind that bezel.. A 15mm torx head (T-15) will be needed to get the headlight bezels off. Sometime the bezels are held on the top with 9/32 headed screws but mostly with more t-15 screws. there is a bolt down low in the front behind the bumper tht attaches the grille filler to the fender and a bunch down near the charcoal canister. open the door and get one of the upper, rear ones with a 9/16 and the extension. another 9/16 on bottom inside the fender and one from the top near hood hinge. (3) 9/16 and the rest should be 1/2". DAVE
"been there, done that, ruined the T-shirt". 2007 LBZ GMC Sierra, ECSB 2006 LM7 RCSB Silverado 98 Vortec project. 94,3500,6.5L 4L80 81 SWB GMC POS finally gone ![]() 73 Pinto, stock, w/CragarSS's-eww ![]() LOTS of Cummins trucks. |
#18 |
OK, well, I got a new set of doors and fenders!
![]() So, my search for doors and fenders is OVER. The only thing that I don't like..is the doors are cut for a 6x9 speaker at the bottom...I wanted to run 6x9's anyway..but I wanted to cut the holes myself... |
#19 |
Congrats on the doors and fenders why cant i ever get that lucky lol
Scott |
#20 | |
#21 |
been here longer than Liz
That's awesome man! Nice to hear of a good find like that.
~Greg~ Mac's Garage '87 SWB 6/8 drop "Piso" '08 CCSB Silverado DD the departed '89 GMC K5 Jimmy 4x4 "Rusty Nuts" '77 Chevy K5 Blazer 2wd '83 Chevy stepside "You get what you pay for" - Mike 'swervin ervin' Ervin |
#22 |
As Cartman would say "YOU BASTARD" .
![]() free, rust free doors & fenders great score ! If you put a piece of sheet metal over the holes and install the factory type carpet bootoms on the doors you can start over and put the speakers wher you want. the carpet bottoms are available aftermarket so you don't have to hunt for good used thatare the right color. They are a fairly easy piece to dye to dark color though. DAVE
#23 | |
Trucker.
#24 | |
http://cgi.ebay.com/ebaymotors/ws/eB...category=33642 Too bad they are in So. Dakota, wrong time of the year to drive there. ![]()
Mitch 1978 Chevrolet Silverado C 10 454 BB, TH400 |
#25 |
Professional Grade
This thread is useless without pictures
