Old 09-29-2005, 12:21 PM   #1
cgrossl
My Ammeter Doesn't Work
All of the gauges in my 72 work fine, except for the Ammeter. Its not that big of a deal, but I would like for it to work. Are there any simple things that I can look for that might fix it? Is there a way to test the gauge?
49 Chevy 3100
69 Camaro
Acro Sport II Biplane
cgrossl is offline   Reply With Quote
Old 09-29-2005, 01:57 PM   #2
byrd
Union Electrician
byrd's Avatar
look under your hood on the drivers side by in the front corner and look a football looking black in line fuse holder, and there is another one like it near the battery on the passengerside. that is what I would check first, and the fuse shoukd be 3-5 amp...Randy
69 Custom-10 SWB FLEETSIDE 350/350 TH Dropped 3.5/5.5"
Help support the board->HERE
Board vendors -> Vendors list
Zip:40272
Big Sandy Survivor...
We cannot choose the way we die, but we can choose the way we live
If you can't fix it with a hammer, you've got an electrical problem.
I think Congressmen should wear uniforms like NASCAR drivers so we could identify their corporate sponsors
byrd is offline   Reply With Quote
Old 09-29-2005, 03:50 PM   #3
4tiresngas
An American Soldier
4tiresngas's Avatar
Cameron, I have the same problem. Both my fuses are brand new. The entire wiring harness is brand new, but the needle on the amp gauge doesn't even hint at moving when I turn the key.
If someone knows how to bench test gauges...Amp, Temp, and the like, that would be awesome.
Dan
dan.brue@us.army.mil
4tiresngas is offline   Reply With Quote
Old 09-29-2005, 03:57 PM   #4
neonlarry
neonlarry's Avatar
Might check out this site:
http://www.fix-a-gauge.com/
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights
99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs
95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI
neonlarry is offline   Reply With Quote
Old 09-29-2005, 04:25 PM   #5
4tiresngas
An American Soldier
4tiresngas's Avatar
Thanks NeonLarry. I ordered the amp and temp gauge kits. It was only $18 with shipping. So, hopefully that will square me away on those two.
Dan
Old 09-29-2005, 04:58 PM   #6
Mongo
YES_____NO
Mongo's Avatar
Let us know if they are worh anything. I for one like to see pictires of what I am buying.
People many not remember what you said or what you did, but they will remember the way you made them feel. - unknown
Cause, remember: no matter where you go... there you are. - Buckaroo Banzai 1984
Mongo is offline   Reply With Quote
Old 09-29-2005, 06:02 PM   #7
byrd
Union Electrician
byrd's Avatar
I use them all the time and I really like the resistors they sell. I haven't used one of their ammeter kits, haven't needed any just my .02 Randy
Zip:40272
Old 09-25-2012, 03:44 PM   #8
louaxtjr
louaxtjr's Avatar
Re: My Ammeter Doesn't Work
Really appreciate you guys. Found this thread using Google and the fuses were not present in my truck. 5 minute fix and my ammeter is working for the first time in 2 years!
_____________________
Lou Axt, Jr.
1969 C10 Longbed 292 inline 6 Offy, Holley, true dual exhaust
tows a 1966 Airstream Tradewind
louaxtjr is offline   Reply With Quote
Old 09-25-2012, 07:06 PM   #9
VetteVet
Msgt USAF Ret
VetteVet's Avatar
The ammeters in our trucks are external shunt types so in order for them to work there has to be a shunt in the wiring between the battery and the alternator. If you rewire the truck and wire the alternator output wire to the starter or the battery you will have eliminated the external shunt and the ammeter will not work.
The external shunt is nothing more than a 12 gauge wire between the right fender terminal post and the alternator regulator battery junction in the left side harness.
Here are 2 pictures to illustrate this.
This is the shunt wiring and the fuses are circled in red.
Here is the joint on my 67. It's the red wires.
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 09-25-2012, 08:56 PM   #10
72 K20
72 K20's Avatar
I've owned all together, past and present 8 of these old trucks and never had an ammeter work until I was informed about these fuses and the role they play. 3 of the 4 I have now have working ammeters. The 4th truck is for parts.
72 K20 is offline   Reply With Quote
Old 09-27-2012, 09:33 AM   #11
73CheyenneSuper20
73CheyenneSuper20's Avatar
Worked for me! Replaced both fuses- one was broken, other fell apart, reconnected wire, my gauge works! That was the only gauge not working, I hadn't gotten around to figuring out why until I found this thread.
'71 C25 Camper Special, 402, TH400, Longbed, Power Loc axle, Figuring out the rest of the details....
'10 Dodge Charger SXT - DD
'91 Kasel M101A2 3/4 ton trailer (It has Chevy rims!)
73CheyenneSuper20 is offline   Reply With Quote
Old 09-27-2012, 09:42 AM   #12
shawno72
C/10 junkie
shawno72's Avatar
Ok guys how about this? I converted my truck from idiot lights to gauges. Installed the fuses and my amp meter gauge worked great. Well I upgraded my old tired looking gauges with some nos units and now the amp gauge has zero movement. Checked fuses and fuses are good, bad gauge maybe? Whats your guys thoughts?
Shawn
70 LWB C10 current driver/project
http://67-72chevytrucks.com/vboard/s...d.php?t=663051
68 SWB C10 Work in progress.....SOLD
http://67-72chevytrucks.com/vboard/s...d.php?t=559520
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
http://youtu.be/kbB0QrBIs9k
My mom always had the best advice. It was just a tad late. After a fall that involved blood, she'd say....."Careful!"
shawno72 is offline   Reply With Quote
Old 09-27-2012, 09:45 AM   #13
jjzepplin
jjzepplin's Avatar
I have a one wire alternator and no regulator. Should my gauge still function?
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
Old 09-27-2012, 04:21 PM   #14
48richard
48richard's Avatar
I have an internally-regulated alternator, and the ammeter does work, but the needle deflection is very small. For example, with the headlights on and the A/C blower on high speed (engine not running), the tip of the needle only moves about 1/8" to the left. Is this normal?
1971 C10 Longbed, 350/TH350
48richard is offline   Reply With Quote
