Old 09-26-2012, 12:09 AM   #1
cameyer
Radiator Over Flow
I just recently bought a 64 k10 and have realized that on longer trips the truck will leak coolant from the overflow hose. the temp always reads normal and i dont see a leak coming from anywhere else. anyone know what could be causing this?
cameyer is offline   Reply With Quote
Old 09-26-2012, 06:02 AM   #2
brokenspoke
brokenspoke's Avatar
Re: Radiator Over Flow
The trucks will seek their own level in the radiator.....or the radiator cap is bad or weak
brokenspoke is offline   Reply With Quote
Old 09-26-2012, 11:16 AM   #3
luvbowties
luvbowties's Avatar
Unhappy Re: Radiator Over Flow
I'd say if you top it off when it is cold--which is best time to open the cap, for safety--that when you drive it & it heats up, it expands and forces the excess out(via overflow tube). I'd also guess that if you install an overflow bucket at the proper level, & with the proper cap, & with the overflow tube flowing 'over' into the bucket, that when it cools off & contracts and creates a partial vacuum, it will siphon/suck the excess back into the radiator. However, I dunno the level OR the type cap that will allow this reverse flow(siphoning back when it cools). Sounds good, tho', doesn't it??? Hopefully someone else will chime in & tell us the rest of the parameters, as I'd like to get my overflow-bucket system siphoning the overflow back into my rad.
sam
luvbowties is offline   Reply With Quote
Old 09-26-2012, 02:44 PM   #4
markeb01
Senior Enthusiast
markeb01's Avatar
This was the normal operating condition for cars and trucks for many decades before coolant recovery systems came into favor. Back in the days when service station attendents washed your windshield, while the tank was being filled the part of the routine "service" at better stations was to check the air in the tires along with the water in the radiator and battery. Topping off all three was frequently needed.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
Old 09-26-2012, 08:46 PM   #5
cameyer
Thanks for the help! I'll look into a new cap first and if that doesn't work I'll see about installing an overflow bucket
Old 09-27-2012, 01:46 PM   #6
64thunder
im thinking of using a sailor jerry bottle or wild turkey bottle for a overflow catcher
64thunder is offline   Reply With Quote
Old 09-27-2012, 07:30 PM   #7
luvbowties
luvbowties's Avatar
Thumbs up Re: Radiator Over Flow
Good choice, especially knowing the WT bottle has already passed a purity test of '101'..............
