Closed Thread
Old 09-28-2012, 09:58 AM   #4951
DevilDog Aggie
DevilDog Aggie's Avatar
Re: What did you do to your truck today!
Installed exhaust manifolds. Thanks for all the info guys! I got them installed last night. Decided to go without gaskets and see what the results are. Both surfaces are clean and straight so I think it should be ok. Let her run for about 30 minutes last night and didn't notice/find any leaks.
Thanks again for everyone's advice!!!
Rob
'72 Chevy C-10 - 350-5.7/TH350/PS/PB/AC
Build Thread - http://67-72chevytrucks.com/vboard/s...87#post5503187
Semper Fi and Gig'em Aggies!
DevilDog Aggie is offline
Old 09-28-2012, 12:35 PM   #4952
Jimbabwe
Jimbabwe's Avatar
Got the bed mounted and the bedsides cut. Raised the bed 1 1/2" so the bottom of the step is even with the cab, instead of hanging lower. Not sure if now lowering the rear to the same ride height with less air in the bag will be a worse ride out back.
Jimbabwe is offline
Old 09-28-2012, 01:31 PM   #4953
Hard Luck
I've got grease on my mind.
Hard Luck's Avatar
Originally Posted by jayman68 View Post
Here are some you might want to check out. Good luck in finding the right fit.
http://67-72chevytrucks.com/vboard/s...d.php?t=314836
They look nice but that's pretty rich for my blood. She's not a race truck and I would rather spend cash elsewhere.
Originally Posted by 71tahoe View Post
Have you tried a full length from a 69 Camaro? Had some on a 69 with 350 but using I6 motor mounts. Tucked pretty nicely.
I would like to see how to use a straight mount, I thought they had a mounting pad at the front of the motor.
Originally Posted by Square_78 View Post
Wow thats insane! I thought shorty Chevelle headers fit? I cant believe that with all the c10's out there, nobody has anything that bolts on and tucks out of the way. I have long tube headers on mine and they hang way below the frame. I need to replace them before I bag the truck. I am looking forward to any other info you post about this. Hopefully the headman headers fit and dont hang down. I was going to order chevelle shortys but I Better hold off for now...
Lonnie
Originally Posted by weever82 View Post
Let me know what works for you! my 69 C10 has some full length Hookers and my passenger side rubs every now and then... drives me nuts.
Weev-
I'll post here when I find something else out.
Cyclone from 71 C10 on left, from 69 Camaro on right.
Attachment 984306
The Chevelle header is supposed to be the same as a Camaro, looks like they depend on the manufacturer.
Called the speed shop again and the new part numbers did not come yet, they said they would call me right back, that was three days ago. I would like to try them out but thought about going to stock manifolds and having them coated. Soaked and pulled apart my Pass side ram horn and it turns out to be 1-7/8" and the Driver's is 2", sooo that's on hold until I can try to pick up another manifold at Monroe next weekend.
Hard Luck is offline
Old 09-28-2012, 01:43 PM   #4954
67cheby
67cheby
67cheby's Avatar
looking great !
67cheby is offline
Old 09-28-2012, 05:04 PM   #4955
jc70chevy
jc70chevy's Avatar
i stared very intensly at my 1972 step side.. wishing i could get out this funk and want this motor but.. no luck....
jc70chevy is offline
Old 09-28-2012, 05:05 PM   #4956
jc70chevy
jc70chevy's Avatar
statring very intensly at my 1972 stepside with the 454 in it.. wishing i had some motivation to get under it and yant motor out to re bearing it...
Old 09-28-2012, 05:19 PM   #4957
shawno72
C/10 junkie
shawno72's Avatar
Post some pics. Sometimes that helps motivate me
Or maybe this will help...Before and after.
Shawn
70 LWB C10 current driver/project
http://67-72chevytrucks.com/vboard/s...d.php?t=663051
68 SWB C10 Work in progress.....SOLD
http://67-72chevytrucks.com/vboard/s...d.php?t=559520
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
http://youtu.be/kbB0QrBIs9k
My mom always had the best advice. It was just a tad late. After a fall that involved blood, she'd say....."Careful!"
shawno72 is offline
Old 09-28-2012, 05:21 PM   #4958
heathbirkendahl
Very very clean! Are those Sanderson shorties?
1971 C/10 - Orange & White
2009 GMC 1500 - Lowered 3/4 22' KMC Slides
heathbirkendahl is offline
Old 09-28-2012, 05:24 PM   #4959
Jimbabwe
Jimbabwe's Avatar
That motor looks sweet, Shawn.
Jimbabwe is offline
Old 09-28-2012, 05:30 PM   #4960
shawno72
C/10 junkie
shawno72's Avatar
Thanks guys. No those are Ch ina headers off of eBay. So far they have held up quite well and I am happy with them.
Shawn
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
shawno72 is offline
Old 09-28-2012, 05:30 PM   #4961
magwakeenercew2jh
RAT1968 '68 Cab/'71 Parts
magwakeenercew2jh's Avatar
Yeah,. Me, too.
What you really need jc70, is a couple of Buds to come around Vallejo (where I'm thinking it's probably pretty much cooler than the 100.8 degrees here today),
climb under with some wrenches and do some bench racing while we pull that puppy.
You have the 454 that need bearings. I have leaks.
Then again, I just found out my brother has stage IV throat cancer. Puts a lot of stuff in perspective.
Put the call out for some wrenches. If it's during the end of next week, I'm only about three and a half hours from you.
Bet there's some other folks that that are close enough and would like to get dirty and then get to go home.
M17
Coarsegold, CA
RAT's shiny now.
But always a rat.
magwakeenercew2jh is offline
Old 09-28-2012, 05:41 PM   #4962
Jimbabwe
Jimbabwe's Avatar
Originally Posted by 67cheby View Post
looking great !
If you meant me, thank you!
Jimbabwe is offline
Old 09-28-2012, 05:51 PM   #4963
Square_78
Square_78's Avatar
Attachment 991267
Those headers clear the frame and motor mounts ok? Im looking for a cheap shorty header solution. Can you please private message me a link to the seller?
#teamlongbed
"I refuse to go disc brakes. I actually love drum brakes. It makes for an adventure." - 50bomb
1978 Chevy shop truck - static 6/8"
1970 GMC 1500 - Accuair eLevel Resto-mod http://67-72chevytrucks.com/vboard/s...d.php?t=537497
Square_78 is offline
Old 09-28-2012, 05:54 PM   #4964
jc70chevy
jc70chevy's Avatar
thanks guys it did help now hoping i can do this motor justice like urs. thanks
Old 09-28-2012, 05:59 PM   #4965
shawno72
C/10 junkie
shawno72's Avatar
Just barely. My engine is mounted in the six cylinder position so it clears the engine stands by about 1/16".
Shawn
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
shawno72 is offline
Old 09-28-2012, 06:00 PM   #4966
shawno72
C/10 junkie
shawno72's Avatar
Anytime, that's one of the beauty's of this forum....motivation!!
Shawn
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
shawno72 is offline
Old 09-28-2012, 06:08 PM   #4967
Jimbabwe
Jimbabwe's Avatar
Shawn, did you gloss powdercoat the air cleaner? I mostly see them (like mine) satin. I'm liking the shiny better.
Jimbabwe is offline
Old 09-28-2012, 06:13 PM   #4968
shawno72
C/10 junkie
shawno72's Avatar
No I gloss painted it I am actually running a differant air cleaner cause that one was to restrictive.
Shawn
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
shawno72 is offline
Old 09-28-2012, 07:16 PM   #4969
Andy4639
Old member
Andy4639's Avatar
Wink Re: What did you do to your truck today!
I drove it for awhile today then took the hood loose again to mess with the gaps. I just couldn't get them any better than these pictures. I installed rebuilt hinges and did a few adjustments when I installed them. Then again today to try and get the drivers side better but it just ant going to happen I guess. I took it loose a bunch and did what I thought would even it up. It either wouldn't shut are it would hit the fenders.
I know these trucks weren't the best body lines for straightness so I'll live with it. The back of the hood sits down now like it should though!
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Andy4639 is offline
Old 09-28-2012, 08:20 PM   #4970
69GWC
Looks to me if the hole front was shifted over you could get your gaps even.
69GWC is offline
Old 09-28-2012, 09:28 PM   #4971
Andy4639
Old member
Andy4639's Avatar
Question Re: What did you do to your truck today!
Are you saying take the core support loose and it may straighten up. I put the new grille in it when I had it painted so the front could be off.
Andy4639 is offline
Old 09-28-2012, 10:24 PM   #4972
69GWC
Yes IMO the front is out of square and needs to be shifted to the drives side so each side of the hood can get the same gaps.
I would guess if you loosed all the front bolts you could shift the front over to fix that.
69GWC is offline
Old 09-28-2012, 10:37 PM   #4973
Andy4639
Old member
Andy4639's Avatar
Thanks I may start on that tomorrow.
Andy4639 is offline
Old 09-28-2012, 11:47 PM   #4974
pat 70/71
pat 70/71's Avatar
Went to my shop and dropped my 70 stepper of the life & gave her a bath and a small detail job and took her and my wifie to a local cruise night. Lots of great rides here in Camarillo old town. Cheers, Pat
pat 70/71 is offline
Old 09-29-2012, 01:48 AM   #4975
mud.man.rj
mud.man.rj's Avatar
Well took my truck for a run yesterday but the big block was a bit cold and I almost stalled it so sidestepped the clutch a bit and turned at the same time while shooting out a tooth from the side spider gears right thu the rear cover so brought it home and gutted the rear diff. Now I need some info guy's in the know. I have a crappy 73 and up gov. lock posi unit, could put new spiders in but is it worth it, heard they are the "worst" GM diff. Will an Eaton or Auburn posi unit swap in place in the same diff housing (12 bolt). Here are a few pic's. Too much power and tire combo.Haha.
So anyone in the know on the swap.
mud.man.rj is offline
Closed Thread
