Old 09-28-2012, 04:34 PM   #1
jrblanke
"while your at it" items when installing 3/4 drop kit
Hey guys,
I was just wondering what extra "while your at it" items you would give attention to when installing the 3/4 drop kit (front spindles, hanger/shackles)? I'm thinking about replacing the ball joints, and dropping the fuel tanks to clean them out. I also might paint the wheels while they are off.
Any other suggestions?
Thanks,
James
jrblanke is offline   Reply With Quote
Old 09-28-2012, 04:46 PM   #2
UKNOWME
UKNOWME's Avatar
Re: "while your at it" items when installing 3/4 drop kit
Any and all front end components that are worn since you will need to align if after. Take it to an alignment shop and have them "shake down the front end" and tell you what to replace when you're doing the drop and then take it back to them for the alignment. Just my .02
2018 Audi S5- wife's ride
1980 Chevy Scottsdale http://67-72chevytrucks.com/vboard/s...d.php?t=543511
1981 Chevy Silverado- in pieces
1964 Chevy c10
2017 Jeep Wrangler JKU
UKNOWME is offline   Reply With Quote
Old 09-28-2012, 05:00 PM   #3
54Caddy
GM Addicted
54Caddy's Avatar
When ever i lower a truck i always rebuild the front end at the same time. inner and outer tie rod ends, pitman arm, idler arm, upper lower ball joints, front bearings, a-arm bushings, in the rear would put new bushings in leafs, and new u-joints.
..Mac’s Garage..
73 GMC, 54 Caddy, 2010 Silverado, 68 C10 RIP DAd
My 73 GMC Truck Build Pic
2010 Silverado 4/6 on 24s
IG:MacsGarage
54Caddy is offline   Reply With Quote
Old 10-31-2012, 10:00 AM   #4
UKNOWME
UKNOWME's Avatar
Originally Posted by jrblanke View Post
Hey guys,
Thanks,
James
Have you done your drop yet?
1964 Chevy c10
Old 10-31-2012, 01:03 PM   #5
jrblanke
No, I have not finished doing the drop. I think I started too many things at once and now have not finished any of them.
I did get the bed off this past weekend. I am going to remove and clean the tanks to ensure that I dont have any crap going up to the carb now that I have rebuilt it. Once I get the tanks off, I am going to wire brush and paint the frame,rear end, and springs.
After I paint those items, I will cut the front hangers off and then remove the rear shackles.
Since the front end parts look to be in pretty good shape, and the truck wasn't really loose when I drove it, I will probably not replace the ball joints unless I damage them. I tried to get the tie rod end off and was unsuccessfull. I believe I need a bigger hammer. I have not ever replaced or worked on ball joints/tie rod ends before, so this is a new experience for me.
I will update this thread when I get the suspension parts on.
Old 10-31-2012, 01:08 PM   #6
88Jimmy4x4
88Jimmy4x4's Avatar
you need to replace wheel bearings for sure and check rear leaf bushings they are usually dry rotted
2008 Silverado Z71 RCSB
1991 GMC Jimmy 4x4
1976 GMC Sierra C15 SWB
88Jimmy4x4 is offline   Reply With Quote
Old 10-31-2012, 03:08 PM   #7
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Install polygraphite bushings!! Paint everything with rust proof paint. If not, at least powerwash it all.
Gerardo a.k.a. Mad Chemist
Silverado XST videos
Old 10-31-2012, 04:17 PM   #8
jrblanke
I should have added that my plans were to clean, inspect, and repack the bearings. I have power washed everything from the cab back and I am planning to use an angle grinder to wire brush the frame, springs, and rear end. Then I will paint it with some rustolium primer and paint. I bought spray can primer, but bought black paint that I will put on with a roller. I am replacing the rear shocks with some new ones from procomp (same ones cue ball recommended). I believe I am going to clean and paint the front calipers, dust shields, and A arms as well.
Thanks for the suggestions
